Dell Latitude 5401 SSD Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
13
Past 30 Days:
71
All Time:
228
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 8 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
This guide will show you how to safely and properly remove and replace the SSD from your Dell Latitude 5401.
This process will involve you removing the back panel of the device to gain access to the inner components. The screws you will need to remove are the 8 on the back panel, 3 on the battery, and one screw that holds the SSD in place.
Warning: Ensure that the device is powered off completely before opening up and handling the inner components of the device.
Tools
    1. Dell Latitude 5401 SSD Replacement, Lower Case: step 1, image 1 of 2 Dell Latitude 5401 SSD Replacement, Lower Case: step 1, image 2 of 2
      • Remove the eight 7 mm-long Phillips #1 screws securing the lower case.
      Ask FixBot
    2. Dell Latitude 5401 SSD Replacement: step 2, image 1 of 2 Dell Latitude 5401 SSD Replacement: step 2, image 2 of 2
      • Insert an opening pick into the seam between the lower case and chassis.
      • Slide the pick around the entire perimeter while prying every few centimeters to disengage the retaining clips.
      • Remove the lower case.
      Ask FixBot
    1. Dell Latitude 5401 SSD Replacement, Dell Latitude 5401 Battery Disconnection: step 3, image 1 of 2 Dell Latitude 5401 SSD Replacement, Dell Latitude 5401 Battery Disconnection: step 3, image 2 of 2
      • Grip the battery connector pull tab and pull the connector straight up to disconnect it.
      • To reconnect the battery, align the connector and use a spudger or clean fingernail to push the connector fully into the socket.
      Ask FixBot
    1. Dell Latitude 5401 SSD Replacement, SSD: step 4, image 1 of 2 Dell Latitude 5401 SSD Replacement, SSD: step 4, image 2 of 2
      • Remove the 4 mm Phillips #1 screw at the bottom of the SSD (which sits directly to the left of the battery).
      • Once removed, the SSD will lift up on its own.
      Ask FixBot
    2. Dell Latitude 5401 SSD Replacement: step 5, image 1 of 2 Dell Latitude 5401 SSD Replacement: step 5, image 2 of 2
      • Gently pull the SSD away from the laptop at an angle
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Sean Martin
307 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 71
All Time: 228
