Up to 20% off select tools
Dell Latitude 5401 RAM Replacement
Views: 1.3K
View statistics:
Past 24 Hours:
2
Past 7 Days:
23
Past 30 Days:
107
All Time:
1,305
Comments: 2
2 comments on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 - 20 minutes
Difficulty: Moderate
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓
This guide will demonstrate the process of replacing RAM on a Dell Latitude 5401 series laptop.
Excessive use, poor ventilation, external or internal damage, and power surges may all result in RAM becoming dysfunctional and rendering the laptop useless. By following along, you will learn how to restore your laptop to working condition - allowing you to continue using it and helping to save both money and the environment!
Before you begin the repair, power off your device and disconnect it from the charger.
    1. Dell Latitude 5401 RAM Replacement, RAM: step 1, image 1 of 2 Dell Latitude 5401 RAM Replacement, RAM: step 1, image 2 of 2
      • Disconnect any devices plugged into the computer.
      • Hold the power button down for 5-10 seconds to shutdown the laptop.
      • Note that during installation or removal of any hardware ensure all data has been backed up properly.
      Ask FixBot
    2. Dell Latitude 5401 RAM Replacement: step 2, image 1 of 2 Dell Latitude 5401 RAM Replacement: step 2, image 2 of 2
      • Flip the laptop so the bottom is facing up.
      • Use a small Phillips screwdriver to loosen the eight screws on the back case.
      • The screws are captive and will remain attached loosely to the lower case.
      Ask FixBot
    3. Dell Latitude 5401 RAM Replacement: step 3, image 1 of 3 Dell Latitude 5401 RAM Replacement: step 3, image 2 of 3 Dell Latitude 5401 RAM Replacement: step 3, image 3 of 3
      Tool used on this step:
      Plastic Cards
      $2.99
      Buy
      • Expose the seam that connects the laptop case by pulling on a corner screw while holding the base.
      • Insert a plastic card into the gap.
      • Slide the card around the perimeter of the case to release the clips.
      • Gently pry the laptop apart.
      • This step can be difficult and will take some time and strength!
      Ask FixBot
    4. Dell Latitude 5401 RAM Replacement: step 4, image 1 of 2 Dell Latitude 5401 RAM Replacement: step 4, image 2 of 2
      • Use a small Phillips screwdriver to loosen the single screw securing the battery.
      • Thes screw is captive and should not be removed.
      • If the battery is swollen, be very careful and follow these safety suggestions.
      Ask FixBot
    5. Dell Latitude 5401 RAM Replacement: step 5, image 1 of 2 Dell Latitude 5401 RAM Replacement: step 5, image 2 of 2
      • Carefully remove the battery from the case.
      • Flip the battery over.
      • Grip the battery cable tab and pull the cable from the battery to separate it from the device.
      • Do not bend or twist the battery during the removal.
      Ask FixBot
    6. Dell Latitude 5401 RAM Replacement: step 6, image 1 of 3 Dell Latitude 5401 RAM Replacement: step 6, image 2 of 3 Dell Latitude 5401 RAM Replacement: step 6, image 3 of 3
      • Gently pull the metal arms on both sides of the RAM stick away slightly to release it.
      • The RAM will pop up by a few millimeters.
      • Remove it at an angle and not straight up so you don't damage the socket.
      • Check online to see how to properly dispose of e-waste in your region.
      Ask FixBot
    7. Dell Latitude 5401 RAM Replacement: step 7, image 1 of 2 Dell Latitude 5401 RAM Replacement: step 7, image 2 of 2
      • Insert the new RAM stick into the slot at the same angle that you used to remove the original.
      • Be sure to insert the grooved edge into the socket so the pins line up correctly to avoid damaging the socket and the RAM.
      • Push down on the RAM until you hear a "click".
      • The two metal arms should now hold the RAM in place.
      Ask FixBot
    8. Dell Latitude 5401 RAM Replacement: step 8, image 1 of 1
      • Reconnect the battery cable.
      • Screw the battery back into place.
      Ask FixBot
    9. Dell Latitude 5401 RAM Replacement: step 9, image 1 of 1
      • Using both hands, push the lower cover back onto the laptop.
      • You should hear a "click" when it is correctly attached.
      • Use a small Phillips screwdriver to secure the eight captive screws on the bottom cover.
      Ask FixBot
Congratulations, you have successfully replaced your laptop RAM, saved money, and reduced your carbon footprint!
Author
with
Jordan Millar
169 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 23
Past 30 Days: 107
All Time: 1,305
