Dell Latitude 5401 Battery Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
55
Past 30 Days:
206
All Time:
716
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 8 minutes
Difficulty: Easy
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓
This guide will show you how to safely and properly remove and replace the battery from your Dell Latitude 5401.
This process will involve you removing the back panel of the device to gain access to the inner components. The screws you will need to remove are the 8 on the back panel and the 3 on the battery.
Warning: Ensure that the device is powered off completely before opening up and handling the inner components of the device. The risk of electric shock is possible.
Fix Kit
This kit contains all the parts and tools needed to complete this guide.
Parts
Tools
    1. Dell Latitude 5401 Battery Replacement, Lower Case: step 1, image 1 of 2 Dell Latitude 5401 Battery Replacement, Lower Case: step 1, image 2 of 2
      • Remove the eight 7 mm-long Phillips #1 screws securing the lower case.
      Ask FixBot
    2. Dell Latitude 5401 Battery Replacement: step 2, image 1 of 2 Dell Latitude 5401 Battery Replacement: step 2, image 2 of 2
      • Insert an opening pick into the seam between the lower case and chassis.
      • Slide the pick around the entire perimeter while prying every few centimeters to disengage the retaining clips.
      • Remove the lower case.
      Ask FixBot
    1. Dell Latitude 5401 Battery Replacement, Dell Latitude 5401 Battery Disconnection: step 3, image 1 of 2 Dell Latitude 5401 Battery Replacement, Dell Latitude 5401 Battery Disconnection: step 3, image 2 of 2
      • Grip the battery connector pull tab and pull the connector straight up to disconnect it.
      • To reconnect the battery, align the connector and use a spudger or clean fingernail to push the connector fully into the socket.
      Ask FixBot
    1. Dell Latitude 5401 Battery Replacement, Battery: step 4, image 1 of 1
      • Remove the single 6 mm-long Phillips screw securing the battery.
      Ask FixBot
    2. Dell Latitude 5401 Battery Replacement: step 5, image 1 of 2 Dell Latitude 5401 Battery Replacement: step 5, image 2 of 2
      • Carefully lift up the top of the battery and pull it away from the front of the laptop at an angle.
      Ask FixBot
For optimal performance, after completing this guide, calibrate your newly installed battery.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Alexander Cook
138 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 55
Past 30 Days: 206
All Time: 716
