Up to 20% off select tools
Dell Latitude 5400 RAM Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
26
Past 30 Days:
132
All Time:
787
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
Memory is crucial to a computer's ability to run, by allowing the computer to temporarily store information it is going to use again without using hard drive space. Sometimes memory can fail or you may wish to upgrade your memory for any reason. This guide will show you how to remove and install memory in your Dell Latitude 5400.
    1. Dell Latitude 5400 RAM Replacement, Back Panel: step 1, image 1 of 3 Dell Latitude 5400 RAM Replacement, Back Panel: step 1, image 2 of 3 Dell Latitude 5400 RAM Replacement, Back Panel: step 1, image 3 of 3
      • Loosen the eight captive screws that secure the lower case using a Phillips #1 screwdriver.
      • Use a spudger to pry the back panel away from the laptop.
      Ask FixBot
    1. Dell Latitude 5400 RAM Replacement, RAM: step 2, image 1 of 1
      • Place your fingers on the brackets on either side of the RAM stick push them outwards.
      • The RAM stick will pop up at an angle.
      Ask FixBot
    2. Dell Latitude 5400 RAM Replacement: step 3, image 1 of 1
      • Pull the RAM stick straight out of its slot at the angle it is facing.
      Ask FixBot
Author
with
John Barbato
261 Reputation
2 Guides authored
UMass Dartmouth, Team 3-2, Biswokarma Fall 2025 Member of UMass Dartmouth, Team 3-2, Biswokarma Fall 2025
UMASSD-BISWOKARMA-F25S3G2
5 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 26
Past 30 Days: 132
All Time: 787
