Dell Latitude 5400 Battery Replacement
Views: 1.1K
View statistics:
Past 24 Hours:
6
Past 7 Days:
41
Past 30 Days:
189
All Time:
1,093
Comments: 1
1 comment on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 - 40 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
This guide tells you how to replace the battery in the Dell Latitude 5400 (P92G model). The battery allows your laptop to operate, therefore if your laptop has a defective battery, it may have symptoms such as excessive battery drain, won't charge, unexpected shutdowns, or only operates when plugged into an AC adapter. If you are experiencing any of these problems, please check the Power and Battery section of our troubleshooting resources for assistance prior to starting this repair.
Whenever you are performing an upgrade on the Dell Latitude 5400 that requires opening the laptop, follow the recommended procedure to perform an orderly shutdown, disconnect from any external power source(s), and use appropriate anti-static precautions and ESD-safe tools to avoid damaging internal components. If you notice that the internal battery of your laptop has become swollen or damaged, cease all work and employ the appropriate safety procedures. See Dell's guidelines or your local recycling programs for more information on safe handling and disposal options for electronic waste.
Tools
    1. Dell Latitude 5400 Battery Replacement, Back Panel: step 1, image 1 of 3 Dell Latitude 5400 Battery Replacement, Back Panel: step 1, image 2 of 3 Dell Latitude 5400 Battery Replacement, Back Panel: step 1, image 3 of 3
      • Loosen the eight captive screws that secure the lower case using a Phillips #1 screwdriver.
      • Use a spudger to pry the back panel away from the laptop.
      Ask FixBot
    1. Dell Latitude 5400 Battery Replacement, Battery: step 2, image 1 of 1
      • Disconnect the battery cable from the connector on the system board.
      Ask FixBot
    2. Dell Latitude 5400 Battery Replacement: step 3, image 1 of 1
      • Loosen the single captive screw that secures the battery to the palm rest assembly.
      Ask FixBot
    3. Dell Latitude 5400 Battery Replacement: step 4, image 1 of 2 Dell Latitude 5400 Battery Replacement: step 4, image 2 of 2
      • Lift and slide the battery away from the palm rest assembly.
      Ask FixBot
Yousef Saber
121 Reputation
1 Guide authored
UMass Dartmouth, Team 3-2, Biswokarma Fall 2025 Member of UMass Dartmouth, Team 3-2, Biswokarma Fall 2025
UMASSD-BISWOKARMA-F25S3G2
5 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 41
Past 30 Days: 189
All Time: 1,093
