Dell Latitude 5320 SSD Replacement
Views: 1.1K
View statistics:
Past 24 Hours:
2
Past 7 Days:
25
Past 30 Days:
117
All Time:
1,137
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
Community-Contributed Guide
Introduction
Go to step 1 ↓
Your Dell Latitude 5320 (Model 5320) relies on its solid‑state drive (SSD) to store the operating system, applications, and all user data. If your laptop is running out of storage, freezing unexpectedly, showing corrupted files, or failing to boot, the SSD may be damaged or malfunctioning and require replacement.
Common symptoms of SSD issues include slow performance, repeated blue‑screen errors, and missing files. If you’re unsure whether the problem is hardware‑related, review the Dell Latitude 5320 Troubleshooting Page before beginning this repair.
Replacing the SSD is a straightforward process that requires only basic repair skills. The SSD is secured with a single screw and lifts out at a slight angle.
This guide includes a step where you must apply gentle, controlled force to remove the SSD without bending or damaging it. Pay close attention to the caution note.
Before starting, completely power off your laptop, unplug all power sources, and back up any important data.
Tools
    1. Dell Latitude 5320 SSD Replacement, Battery: step 1, image 1 of 1
      • Remove the seven 6 mm screws on the outer edges of the the bottom of the laptop with a Phillips #0 screwdriver.
      • Loosen the captive screw in the center of the bottom of the laptop using a Phillips #0 screwdriver.
      Ask FixBot
    2. Dell Latitude 5320 SSD Replacement: step 2, image 1 of 3 Dell Latitude 5320 SSD Replacement: step 2, image 2 of 3 Dell Latitude 5320 SSD Replacement: step 2, image 3 of 3
      • Insert an opening tool into the edges of the back plate.
      • You will hear the clips make a popping sound.
      • Once the back plate has become detached, remove it.
      Ask FixBot
    3. Dell Latitude 5320 SSD Replacement: step 3, image 1 of 1
      • Remove the four 5 mm screws that hold the battery in place with a Phillips #0 screwdriver
      Ask FixBot
    4. Dell Latitude 5320 SSD Replacement: step 4, image 1 of 3 Dell Latitude 5320 SSD Replacement: step 4, image 2 of 3 Dell Latitude 5320 SSD Replacement: step 4, image 3 of 3
      • Pull the tab on the press connector to the battery cable to disconnect the battery.
      • This is a delicate wire; make sure to pull on the tab with a gentle, consistent pressure.
      • Remove the battery.
      Ask FixBot
    1. Dell Latitude 5320 SSD Replacement, SSD: step 5, image 1 of 2 Dell Latitude 5320 SSD Replacement, SSD: step 5, image 2 of 2
      • Remove the two 4 mm screws on the bottom edge of the black metal plate with a Phillips #0 screwdriver.
      • Remove the plate by lifting it up.
      Ask FixBot
    2. Dell Latitude 5320 SSD Replacement: step 6, image 1 of 1
      • Remove the blue plastic holder by lifting it up.
      Ask FixBot
    3. Dell Latitude 5320 SSD Replacement: step 7, image 1 of 1
      • Remove the SSD holder by lifting upon the back or middle then sliding it to the left.
      • Be careful not to pull up on the SSD card too harshly as it may damage the pin connectors.
      Ask FixBot
Minecraftchest2
229 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 25
Past 30 Days: 117
All Time: 1,137
