Dell Latitude 5310 Battery Replacement
  1. Dell Latitude 5310 Battery Replacement, open the back cover: step 1, image 1 of 3 Dell Latitude 5310 Battery Replacement, open the back cover: step 1, image 2 of 3 Dell Latitude 5310 Battery Replacement, open the back cover: step 1, image 3 of 3
    • place the laptop upside down on a soft, clean surface to avoid scratching
    • locate the screws (in this case 8)
    • use the screwdriver
    • 'Note: the screws are designe to stay attached in the back cover even after being unscrewed. This prevents loss.'
    • use the opening tool to open the back cover starting on the hinge areas. then move slowly around the edges
    • lift the open areas with your hand (lightly!) and slowly work using the tension along the edges.
    Ask FixBot
  2. Dell Latitude 5310 Battery Replacement, remove the battery: step 2, image 1 of 2 Dell Latitude 5310 Battery Replacement, remove the battery: step 2, image 2 of 2
    • use the screwdriver to remove the screws which also stay attached
    • use your fingers to detach the battery connection cable from the motherboard
    • you can pick up the battery and take it out of the device
    • remove the connections cable from the "old" battery and insert to the new one
    Ask FixBot
  3. Dell Latitude 5310 Battery Replacement, install new battery: step 3, image 1 of 2 Dell Latitude 5310 Battery Replacement, install new battery: step 3, image 2 of 2
    • insert the new battery and screw in
    • use the spudger to fix the connection cable then press with the flat of the spudger side to push it in
    Ask FixBot
    • put the back cover on and use your palm to close softly
    • then screw the back cover back on
    Ask FixBot
    • test if the device is working
    • Note: mostly the batterys are delivered empty so first you need to charge it maybe
    • its also possible to get the status of the battery: press F2 while starting to open bios settings then check battery status
    Ask FixBot
2 other people completed this guide.
Oliver Sandmaier
340 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 55
Past 30 Days: 219
All Time: 3,976
