Introduction
Go to step 1 ↓Use this guide to replace the M.2 NVMe Solid-state drive (SSD) in a Dell Latitude 5300. Whether you are upgrading your storage capacity for more files or replacing a failed drive to get your laptop running again, this process is a quick and efficient way to lengthen the life of your device. The Dell Latitude 5300 features a single M.2 slot. Before beginning, ensure you have backed up any important data, as replacing the drive will require a fresh installation of an operating system.
Peel up the black tape securing the battery cable to the battery.
Use your fingernail to disconnect the battery connector.
Use a Phillips #1 screwdriver to remove the two M2x3 screws holding the SSD extension bracket.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
