Dell Latitude 5300 Fan Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
17
Past 30 Days:
98
All Time:
345
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
If you need to replace the fan assembly in your Dell Latitude 5300, this guide will help you do so. A fan that is either inoperable or not triggering correctly can cause issues such as overheating and excess noise.
Before using this guide, Remove any micro-SD card you may have inserted into the micro-SD slot. Also remember to power off the device completely and disconnect it from any power source. Also, when working with any electronic, make sure you are grounded. This can be done with an anti-static bracelet, or by keeping contact with a grounded metal object nearby.
Tools
    1. Dell Latitude 5300 Fan Replacement, Lower Case: step 1, image 1 of 1
      • Loosen the eight captive screws using Phillips #0 screwdriver.
      • The captive screws are attached to the base cover.
      Ask FixBot
    2. Dell Latitude 5300 Fan Replacement: step 2, image 1 of 2 Dell Latitude 5300 Fan Replacement: step 2, image 2 of 2
      • Pry the cover off of device using an opening pick while lifting the base cover.
      • Work your way around the device prying on all sides to release the base cover.
      • Lift away base cover revealing the interior.
      Ask FixBot
    1. Dell Latitude 5300 Fan Replacement, Dell Latitude 5300 Battery Disconnection: step 3, image 1 of 3 Dell Latitude 5300 Fan Replacement, Dell Latitude 5300 Battery Disconnection: step 3, image 2 of 3 Dell Latitude 5300 Fan Replacement, Dell Latitude 5300 Battery Disconnection: step 3, image 3 of 3
      • Peel up the black tape securing the battery cable to the battery.
      • Use your fingernail to disconnect the battery connector.
      Ask FixBot
    1. Dell Latitude 5300 Fan Replacement, Fan: step 4, image 1 of 2 Dell Latitude 5300 Fan Replacement, Fan: step 4, image 2 of 2
      • Use your fingernails to disconnect the fan connector.
      • Remove the two Phillips #0 screws securing the fan to the chassis.
      • Remove the fan.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Virgil DeAngelis
73 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 17
Past 30 Days: 98
All Time: 345
