Dell Latitude 3520 System Fan Replacement
    1. Dell Latitude 3520 System Fan Replacement, Remove MicroSD-card: step 1, image 1 of 1
      • Push the microSD-card to eject it from the slot.
      • Remove the microSD-card from the computer.
      Ask FixBot
    1. Dell Latitude 3520 System Fan Replacement, Bottom Case: step 2, image 1 of 3 Dell Latitude 3520 System Fan Replacement, Bottom Case: step 2, image 2 of 3 Dell Latitude 3520 System Fan Replacement, Bottom Case: step 2, image 3 of 3
      • Loosen the nine screws 2mm Phillips #0 that secure the base cover to the assembly.
      • Using a plastic scribe, pry open the base cover starting from the recesses located in the indents near the hinges at the top edge of the base cover.
      • Carefully lift and remove the base cover.
      Ask FixBot
    1. Dell Latitude 3520 System Fan Replacement, Battery: step 3, image 1 of 1
      • Use the white side to disconnect. The rainbow side is extremely difficult to get back together
      • Slide the metal above the connector on the battery to unlock. -DO NOT USE THE RAINBW SIDE TO DISCONNECT. USE THE WHITE SIDE.
      Ask FixBot
    2. Dell Latitude 3520 System Fan Replacement: step 4, image 1 of 2 Dell Latitude 3520 System Fan Replacement: step 4, image 2 of 2
      • Peel the adhesive tapes and the battery cable.
      Ask FixBot
    3. Dell Latitude 3520 System Fan Replacement: step 5, image 1 of 1
      • Disconnect the battery cable from the connector on the system board.
      Ask FixBot
    4. Dell Latitude 3520 System Fan Replacement: step 6, image 1 of 2 Dell Latitude 3520 System Fan Replacement: step 6, image 2 of 2
      • Remove the three 2mm Phillip #0 screws that secure the battery in place.
      Ask FixBot
    5. Dell Latitude 3520 System Fan Replacement: step 7, image 1 of 1
      • Lift and remove the battery.
      Ask FixBot
    1. Dell Latitude 3520 System Fan Replacement, System Fan: step 8, image 1 of 1
      • Disconnect the system fan cable from the connector on the system board.
      Ask FixBot
    2. Dell Latitude 3520 System Fan Replacement: step 9, image 1 of 1
      • Remove the two 2mm Phillips #0 screws that secure the system fan.
      Ask FixBot
    3. Dell Latitude 3520 System Fan Replacement: step 10, image 1 of 1
      • Lift and remove the system fan.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 31
Past 30 Days: 103
All Time: 927
