Dell Latitude 3520 Battery Replacement
Views: 4.8K
View statistics:
Past 24 Hours:
5
Past 7 Days:
70
Past 30 Days:
342
All Time:
4,842
Comments: 2
2 comments on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 2 - 8 minutes
Difficulty: Easy
Needs More Images
A few more images would make this guide's procedures crystal clear.
Introduction
Go to step 1 ↓
Please refer to this manual for instructions on replacing your computer's battery. Ensure you have the necessary tools on hand, including a plastic scribe and a Phillips 0 driver.
By following a few straightforward steps, you can effectively address battery-related problems and restore your laptop's optimal performance. Given the crucial role of the laptop battery, it is imperative to promptly tackle any battery issues.
Fix Kit
This kit contains all the parts and tools needed to complete this guide.
Parts
Tools
  • Phillips #0 Screwdriver
    5
  • Spudger
    4.9
    1. Dell Latitude 3520 Battery Replacement, Remove MicroSD-card: step 1, image 1 of 1
      • Push the microSD-card to eject it from the slot.
      • Remove the microSD-card from the computer.
      Ask FixBot
    1. Dell Latitude 3520 Battery Replacement, Bottom Case: step 2, image 1 of 3 Dell Latitude 3520 Battery Replacement, Bottom Case: step 2, image 2 of 3 Dell Latitude 3520 Battery Replacement, Bottom Case: step 2, image 3 of 3
      • Loosen the nine screws 2mm Phillips #0 that secure the base cover to the assembly.
      • Using a plastic scribe, pry open the base cover starting from the recesses located in the indents near the hinges at the top edge of the base cover.
      • Carefully lift and remove the base cover.
      Ask FixBot
    1. Dell Latitude 3520 Battery Replacement, Battery: step 3, image 1 of 1
      • Use the white side to disconnect. The rainbow side is extremely difficult to get back together
      • Slide the metal above the connector on the battery to unlock. -DO NOT USE THE RAINBW SIDE TO DISCONNECT. USE THE WHITE SIDE.
      Ask FixBot
    2. Dell Latitude 3520 Battery Replacement: step 4, image 1 of 2 Dell Latitude 3520 Battery Replacement: step 4, image 2 of 2
      • Peel the adhesive tapes and the battery cable.
      Ask FixBot
    3. Dell Latitude 3520 Battery Replacement: step 5, image 1 of 1
      • Disconnect the battery cable from the connector on the system board.
      Ask FixBot
    4. Dell Latitude 3520 Battery Replacement: step 6, image 1 of 2 Dell Latitude 3520 Battery Replacement: step 6, image 2 of 2
      • Remove the three 2mm Phillip #0 screws that secure the battery in place.
      Ask FixBot
    5. Dell Latitude 3520 Battery Replacement: step 7, image 1 of 1
      • Lift and remove the battery.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 70
Past 30 Days: 342
All Time: 4,842
