Dell Latitude 3500 System Board Replacement
    1. Dell Latitude 3500 System Board Replacement, Remove screws: step 1, image 1 of 1
      • 10 screws hold the bottom cover in place -- these stay in the bottom cover.
      Ask FixBot
    2. Dell Latitude 3500 System Board Replacement, Separate bottom cover and palmrest: step 2, image 1 of 1
      • Using a spudger will make quick work of this step.
      Ask FixBot
    1. Dell Latitude 3500 System Board Replacement, Disconnect and Remove Battery: step 3, image 1 of 1
      • Disconnect the battery cable from the motherboard.
      • Remove the 4 screws holding it in place
      • Battery can now be removed from device.
      Ask FixBot
    1. Dell Latitude 3500 System Board Replacement, Disconnect Surrounding Connections from System Fan: step 4, image 1 of 1
      • Unplug the fan header
      • Unplug the VGA board cable
      • Unplug the LCD cable
      Ask FixBot
    2. Dell Latitude 3500 System Board Replacement, Remove Fan Screws: step 5, image 1 of 1
      • Once these 2 screws are removed the fan will lift out as long as the cables are out of the way.
      Ask FixBot
    1. Dell Latitude 3500 System Board Replacement, Loosen Screws: step 6, image 1 of 1
      • Loosen the 7 screws in sequential order as labeled on the heatsink [1, 2, 3, 4, 5, 6, 7]
      • Lift heatsink out of device
      • To replace these screws: place the heatsink, line up the screw holes, then tighten the screws in the same sequential order labeled on the heatsink.
      Ask FixBot
    1. Dell Latitude 3500 System Board Replacement, Unscrew Bracket: step 7, image 1 of 1
      • Holds down card and keeps antenna in place
      Ask FixBot
    2. Dell Latitude 3500 System Board Replacement, Disconnect Antennas: step 8, image 1 of 1
      • Carefully remove the two antennas from their slots.
      • The card should slide right out for easy replacement.
      Ask FixBot
    1. Dell Latitude 3500 System Board Replacement, Remove Shroud: step 9, image 1 of 1
      • 1 screw
      Ask FixBot
    2. Dell Latitude 3500 System Board Replacement, Remove M.2 Drive: step 10, image 1 of 1
      • 1 screw
      Ask FixBot
    1. Dell Latitude 3500 System Board Replacement, Lift Latches: step 11, image 1 of 1
      • Two clamps hold the RAM module in place, once these are moved the module will slide out of the slot and can be replaced.
      Ask FixBot
    1. Dell Latitude 3500 System Board Replacement, Disconnect Remaining Connections: step 12, image 1 of 1
      • 8 remaining connections: IO Board, VGA Board, power button board, display ribbon, touchpad, keyboard, speakers, and PWR.
      Ask FixBot
    2. Dell Latitude 3500 System Board Replacement, Remove Screws: step 13, image 1 of 1
      • 4 screws total
      • Board will then lift out
      Ask FixBot
Jake
1,336 Reputation
14 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 11
Past 30 Days: 44
All Time: 650
