Dell Latitude 3500 Power Button Board Replacement
    1. Dell Latitude 3500 Power Button Board Replacement, Remove screws: step 1, image 1 of 1
      • 10 screws hold the bottom cover in place -- these stay in the bottom cover.
      Ask FixBot
    2. Dell Latitude 3500 Power Button Board Replacement, Separate bottom cover and palmrest: step 2, image 1 of 1
      • Using a spudger will make quick work of this step.
      Ask FixBot
    1. Dell Latitude 3500 Power Button Board Replacement, Disconnect and Remove Battery: step 3, image 1 of 1
      • Disconnect the battery cable from the motherboard.
      • Remove the 4 screws holding it in place
      • Battery can now be removed from device.
      Ask FixBot
    1. Dell Latitude 3500 Power Button Board Replacement, Disconnect Surrounding Connections from System Fan: step 4, image 1 of 1
      • Unplug the fan header
      • Unplug the VGA board cable
      • Unplug the LCD cable
      Ask FixBot
    2. Dell Latitude 3500 Power Button Board Replacement, Remove Fan Screws: step 5, image 1 of 1
      • Once these 2 screws are removed the fan will lift out as long as the cables are out of the way.
      Ask FixBot
    1. Dell Latitude 3500 Power Button Board Replacement, Disconnect Ribbon Cable: step 6, image 1 of 1
      • Insert wisdom here.
      Ask FixBot
    2. Dell Latitude 3500 Power Button Board Replacement, Lift Left-Side Hinge: step 7, image 1 of 1
      • 2 screws total
      Ask FixBot
    3. Dell Latitude 3500 Power Button Board Replacement, Remove Board: step 8, image 1 of 1
      • 2 screws total
      Ask FixBot
Jake
1,336 Reputation
14 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 35
All Time: 311
