Up to 20% off select tools
Dell Latitude 3440 RAM Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
14
Past 30 Days:
88
All Time:
421
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
If your Dell Latitude 3440 RAM is not working properly e.g., the device being slow or experiencing crashes due to insufficient memory, use this guide to replace the RAM.
The primary function of a RAM is to enable fast multitasking and program loading; a faulty RAM will result in frequent crashes or restarts.
    1. Dell Latitude 3440 RAM Replacement, Battery: step 1, image 1 of 2 Dell Latitude 3440 RAM Replacement, Battery: step 1, image 2 of 2
      • Slide the battery latches outwards in opposite directions.
      • Remove the battery from the device.
      Ask FixBot
    1. Dell Latitude 3440 RAM Replacement, RAM: step 2, image 1 of 1
      • Remove the SD memory card by pressing on the card to release it from the computer.
      Ask FixBot
    2. Dell Latitude 3440 RAM Replacement: step 3, image 1 of 2 Dell Latitude 3440 RAM Replacement: step 3, image 2 of 2
      • Remove the single 4.7mm screw from the access panel using a Phillips #1 screwdriver.
      • Remove the panel.
      Ask FixBot
    3. Dell Latitude 3440 RAM Replacement: step 4, image 1 of 1
      • Separate the securing clips holding in the RAM.
      Ask FixBot
    4. Dell Latitude 3440 RAM Replacement: step 5, image 1 of 1
      • Remove the RAM from the board by lifting gently and pulling out slightly.
      • Pulling straight up could damage the pins on the RAM module.
      Ask FixBot
Author
with
Gabe Jang
755 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 14
Past 30 Days: 88
All Time: 421
