Dell Latitude 3420 SSD Replacement
    1. Dell Latitude 3420 SSD Replacement, Battery: step 1, image 1 of 2 Dell Latitude 3420 SSD Replacement, Battery: step 1, image 2 of 2
      • Remove the five 3 mm-long Phillips screws securing the battery.
      Ask FixBot
    2. Dell Latitude 3420 SSD Replacement: step 2, image 1 of 2 Dell Latitude 3420 SSD Replacement: step 2, image 2 of 2
      • Use an opening tool to gently push the battery connector directly out of its motherboard socket.
      • Disconnect the second cable by pushing the connector toward the battery as well.
      Ask FixBot
    3. Dell Latitude 3420 SSD Replacement: step 3, image 1 of 2 Dell Latitude 3420 SSD Replacement: step 3, image 2 of 2
      • Slowly lift the battery out of the laptop housing.
      Ask FixBot
    1. Dell Latitude 3420 SSD Replacement, SSD: step 4, image 1 of 2 Dell Latitude 3420 SSD Replacement, SSD: step 4, image 2 of 2
      • Remove the single 3 mm-long Phillips #00 screw securing the SSD.
      • The SSD will lift a few millimeters.
      Ask FixBot
    2. Dell Latitude 3420 SSD Replacement: step 5, image 1 of 2 Dell Latitude 3420 SSD Replacement: step 5, image 2 of 2
      • Pull the SSD directly out of its socket.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Sam Bradford
219 Reputation
2 Guides authored
UMass Dartmouth, Team 1-3, Botvin Fall 2025 Member of UMass Dartmouth, Team 1-3, Botvin Fall 2025
UMASSD-BOTVIN-F25S1G3
3 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 34
Past 30 Days: 125
All Time: 642
