Dell Latitude 3420 Lower Case Replacement
    1. Dell Latitude 3420 Lower Case Replacement, Lower Case: step 1, image 1 of 1
      • Shut down the laptop and disconnect all peripheries before beginning.
      • Close the laptop lid and set the laptop down with the lower case facing you.
      • Use a Phillips #00 screwdriver to remove the seven 7 mm-long screws securing the lower case.
      Ask FixBot
    2. Dell Latitude 3420 Lower Case Replacement: step 2, image 1 of 2 Dell Latitude 3420 Lower Case Replacement: step 2, image 2 of 2
      • Insert an opening tool into the seam between the lower case and chassis.
      • Pry around the entire perimeter until the lower case fully releases.
      • Remove the lower case.
      Ask FixBot
Connor Bassolino
25,364 Reputation
125 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 33
All Time: 214
