Dell Latitude 3420 Fan Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
20
Past 30 Days:
92
All Time:
436
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 - 20 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
If your Latitude 3420 is running hot, making loud sounds, or shutting down from overheating, the internal fan might need to be replaced. The fan keeps your laptop cool by moving heat away from the processor. A failing fan can damage other parts if left unfixed. This repair requires opening the laptop, disconnecting the fan cable, removing the fan assembly, and installing a new cooling unit. Once it is secured and plugged back in, reassemble the laptop.
Tools
    1. Dell Latitude 3420 Fan Replacement, Lower Case: step 1, image 1 of 1
      • Shut down the laptop and disconnect all peripheries before beginning.
      • Close the laptop lid and set the laptop down with the lower case facing you.
      • Use a Phillips #00 screwdriver to remove the seven 7 mm-long screws securing the lower case.
      Ask FixBot
    2. Dell Latitude 3420 Fan Replacement: step 2, image 1 of 2 Dell Latitude 3420 Fan Replacement: step 2, image 2 of 2
      • Insert an opening tool into the seam between the lower case and chassis.
      • Pry around the entire perimeter until the lower case fully releases.
      • Remove the lower case.
      Ask FixBot
    1. Dell Latitude 3420 Fan Replacement, Battery: step 3, image 1 of 2 Dell Latitude 3420 Fan Replacement, Battery: step 3, image 2 of 2
      • Remove the five 3 mm-long Phillips screws securing the battery.
      Ask FixBot
    2. Dell Latitude 3420 Fan Replacement: step 4, image 1 of 2 Dell Latitude 3420 Fan Replacement: step 4, image 2 of 2
      • Use an opening tool to gently push the battery connector directly out of its motherboard socket.
      • Disconnect the second cable by pushing the connector toward the battery as well.
      Ask FixBot
    3. Dell Latitude 3420 Fan Replacement: step 5, image 1 of 2 Dell Latitude 3420 Fan Replacement: step 5, image 2 of 2
      • Slowly lift the battery out of the laptop housing.
      Ask FixBot
    1. Dell Latitude 3420 Fan Replacement, Fan: step 6, image 1 of 1
      • Remove the sliding connector for the wire connected to the fan.
      • Remove any adhesives keeping the fan down as well.
      Ask FixBot
    2. Dell Latitude 3420 Fan Replacement: step 7, image 1 of 1
      • Remove the two 3 mm-long Phillips screws that secure the fan.
      Ask FixBot
    3. Dell Latitude 3420 Fan Replacement: step 8, image 1 of 3 Dell Latitude 3420 Fan Replacement: step 8, image 2 of 3 Dell Latitude 3420 Fan Replacement: step 8, image 3 of 3
      • Remove the fan by lifting it away from the computer.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Collin Roque
112 Reputation
1 Guide authored
UMass Dartmouth, Team 1-3, Botvin Fall 2025 Member of UMass Dartmouth, Team 1-3, Botvin Fall 2025
UMASSD-BOTVIN-F25S1G3
3 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 20
Past 30 Days: 92
All Time: 436
