Dell Latitude 3380 Motherboard Replacement
    1. Dell Latitude 3380 Motherboard Replacement, Back Cover: step 1, image 1 of 2 Dell Latitude 3380 Motherboard Replacement, Back Cover: step 1, image 2 of 2
      • Turn the laptop over so that the back is facing up.
      • Remove the nine 3 mm screws with a Phillips #0 screwdriver.
      Ask FixBot
    2. Dell Latitude 3380 Motherboard Replacement: step 2, image 1 of 2 Dell Latitude 3380 Motherboard Replacement: step 2, image 2 of 2
      • Use an opening tool to pry the back cover away from the laptop.
      Ask FixBot
    1. Dell Latitude 3380 Motherboard Replacement, Motherboard: step 3, image 1 of 3 Dell Latitude 3380 Motherboard Replacement, Motherboard: step 3, image 2 of 3 Dell Latitude 3380 Motherboard Replacement, Motherboard: step 3, image 3 of 3
      • Remove the four 3 mm screws holding the battery in place using a Phillips #0 screwdriver.
      • Disconnect the battery cable by gently pulling it out.
      • Remove the battery.
      Ask FixBot
    2. Dell Latitude 3380 Motherboard Replacement: step 4, image 1 of 3 Dell Latitude 3380 Motherboard Replacement: step 4, image 2 of 3 Dell Latitude 3380 Motherboard Replacement: step 4, image 3 of 3
      • Remove the 3 mm screw from the WLAN card using a Phillips #0 screwdriver.
      • Disconnect and remove the WLAN card.
      Ask FixBot
    3. Dell Latitude 3380 Motherboard Replacement: step 5, image 1 of 3 Dell Latitude 3380 Motherboard Replacement: step 5, image 2 of 3 Dell Latitude 3380 Motherboard Replacement: step 5, image 3 of 3
      • Disconnect the audio cable.
      • Remove the entire audio card piece.
      Ask FixBot
    4. Dell Latitude 3380 Motherboard Replacement: step 6, image 1 of 3 Dell Latitude 3380 Motherboard Replacement: step 6, image 2 of 3 Dell Latitude 3380 Motherboard Replacement: step 6, image 3 of 3
      • Remove the two 5 mm screws from the fan using a Phillips #0 screwdriver.
      • Loosen the four captive screws on the heatsink using a Phillips #0 screwdriver.
      • Remove the heatsink from the motherboard.
      Ask FixBot
    5. Dell Latitude 3380 Motherboard Replacement: step 7, image 1 of 2 Dell Latitude 3380 Motherboard Replacement: step 7, image 2 of 2
      Tool used on this step:
      Buy
      • Using tweezers, loosen the power connector from the fan to the motherboard, fully disconnecting the fan.
      Ask FixBot
    6. Dell Latitude 3380 Motherboard Replacement: step 8, image 1 of 3 Dell Latitude 3380 Motherboard Replacement: step 8, image 2 of 3 Dell Latitude 3380 Motherboard Replacement: step 8, image 3 of 3
      • Using a Phillips #0 screwdriver, unscrew and remove this metal plate.
      • Gently disconnect the cable under the metal plate.
      Ask FixBot
    7. Dell Latitude 3380 Motherboard Replacement: step 9, image 1 of 2 Dell Latitude 3380 Motherboard Replacement: step 9, image 2 of 2
      • Disconnect the battery power cable.
      Ask FixBot
    8. Dell Latitude 3380 Motherboard Replacement: step 10, image 1 of 2 Dell Latitude 3380 Motherboard Replacement: step 10, image 2 of 2
      • Disconnect the power cable that connects to the charging port.
      Ask FixBot
    9. Dell Latitude 3380 Motherboard Replacement: step 11, image 1 of 2 Dell Latitude 3380 Motherboard Replacement: step 11, image 2 of 2
      • Disconnect the touchpad cable.
      Ask FixBot
    10. Dell Latitude 3380 Motherboard Replacement: step 12, image 1 of 2 Dell Latitude 3380 Motherboard Replacement: step 12, image 2 of 2
      • Remove the five screws from the motherboard using a Phillips #0 screwdriver.
      • Remove the motherboard.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 59
All Time: 1,180
