Dell Latitude 3380 Front Camera Replacement
    1. Dell Latitude 3380 Front Camera Replacement, Back Cover: step 1, image 1 of 2 Dell Latitude 3380 Front Camera Replacement, Back Cover: step 1, image 2 of 2
      • Turn the laptop over so that the back is facing up.
      • Remove the nine 3 mm screws with a Phillips #0 screwdriver.
      Ask FixBot
    2. Dell Latitude 3380 Front Camera Replacement: step 2, image 1 of 2 Dell Latitude 3380 Front Camera Replacement: step 2, image 2 of 2
      • Use an opening tool to pry the back cover away from the laptop.
      Ask FixBot
    1. Dell Latitude 3380 Front Camera Replacement, Front Camera: step 3, image 1 of 2 Dell Latitude 3380 Front Camera Replacement, Front Camera: step 3, image 2 of 2
      • Disconnect the cable strip.
      Ask FixBot
    2. Dell Latitude 3380 Front Camera Replacement: step 4, image 1 of 1
      • Detach the power cable connecting the display to the motherboard.
      Ask FixBot
    3. Dell Latitude 3380 Front Camera Replacement: step 5, image 1 of 1
      • Remove the four screws holding the display in place using a Phillips #0 screwdriver.
      Ask FixBot
    4. Dell Latitude 3380 Front Camera Replacement: step 6, image 1 of 2 Dell Latitude 3380 Front Camera Replacement: step 6, image 2 of 2
      • Using your fingers (or an opening tool if necessary), gently pry off the bottom cover on the display.
      Ask FixBot
    5. Dell Latitude 3380 Front Camera Replacement: step 7, image 1 of 2 Dell Latitude 3380 Front Camera Replacement: step 7, image 2 of 2
      • Remove the screw caps, then the screws using a Phillips #0 screwdriver.
      • Remove the plastic outer covering using an opening tool.
      Ask FixBot
    6. Dell Latitude 3380 Front Camera Replacement: step 8, image 1 of 3 Dell Latitude 3380 Front Camera Replacement: step 8, image 2 of 3 Dell Latitude 3380 Front Camera Replacement: step 8, image 3 of 3
      Tool used on this step:
      Buy
      • Remove the front camera by gently pulling it out with a pair of tweezers.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 16
Past 30 Days: 64
All Time: 425
