Dell Latitude 3380 Fan Replacement
    1. Dell Latitude 3380 Fan Replacement, Back Cover: step 1, image 1 of 2 Dell Latitude 3380 Fan Replacement, Back Cover: step 1, image 2 of 2
      • Turn the laptop over so that the back is facing up.
      • Remove the nine 3 mm screws with a Phillips #0 screwdriver.
      Ask FixBot
    2. Dell Latitude 3380 Fan Replacement: step 2, image 1 of 2 Dell Latitude 3380 Fan Replacement: step 2, image 2 of 2
      • Use an opening tool to pry the back cover away from the laptop.
      Ask FixBot
    1. Dell Latitude 3380 Fan Replacement, Fan: step 3, image 1 of 1
      • Remove the two 5 mm screws from the fan using a Phillips #0 screwdriver.
      Ask FixBot
    2. Dell Latitude 3380 Fan Replacement: step 4, image 1 of 1
      • Loosen the four captive screws on the heatsink using a Phillips #0 screwdriver.
      Ask FixBot
    3. Dell Latitude 3380 Fan Replacement: step 5, image 1 of 1
      • Remove the heatsink from the motherboard.
      Ask FixBot
    4. Dell Latitude 3380 Fan Replacement: step 6, image 1 of 2 Dell Latitude 3380 Fan Replacement: step 6, image 2 of 2
      Tool used on this step:
      Buy
      • Using tweezers, loosen the power connector from the fan to the motherboard, fully disconnecting the fan.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 21
Past 30 Days: 74
All Time: 434
