Introduction
Whether you need to upgrade your storage, or replace a damaged hard drive, this guide will show you all steps needed to swap out the M.2 Solid State Drive in your system.
The Dell Latitude 3310 supports both 2230 and 2280 size M.2 drives.
It's important to understand that removing the hard drive will remove ALL data from your system. Back up any important files before proceeding!
Remove seven 8.0 mm screws using a Phillips #1 screwdriver.
Remove three 5.0 mm screws using a Phillips #1 screwdriver.
Using a Phillips #1 screwdriver remove the 3.5 mm screw securing the drive to the board.
Gently pull the drive out of the slot.
