Introduction
Go to step 1 ↓If your Dell Latitude 3310 laptop is overheating often or you hear strange noises coming from it, then you may need to replace your system fan.
Parts
Tools
Remove seven 8.0 mm screws using a Phillips #1 screwdriver.
Remove three 5.0 mm screws using a Phillips #1 screwdriver.
Remove the two 3 mm screws that hold the fan in place using a Phillips #1 screwdriver.
