Dell Latitude 3190 Keyboard Replacement
Views: 2.3K
View statistics:
Past 24 Hours:
4
Past 7 Days:
31
Past 30 Days:
101
All Time:
2,275
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 30 - 45 minutes
Difficulty: Moderate
Inconsistent Images
Updating the images on this guide to be more consistent with the prerequisites would increase its awesomeness.
Introduction
Go to step 1 ↓
The keyboard is the main source of communication between the user and the laptop. Without it, the laptop has very limited capability. Before replacing your keyboard, attempt to clean under the keys with a can of air and a microfiber cloth. If your Dell Latitude 3190 keyboard has missing or broke keys or has stopped functioning altogether, follow this guide to replace the keyboard. Make sure your device is powered off and unplugged from external power before beginning the repair.
Tools
    1. Dell Latitude 3190 Keyboard Replacement, Base Cover: step 1, image 1 of 2 Dell Latitude 3190 Keyboard Replacement, Base Cover: step 1, image 2 of 2
      • Use a Phillips #0 screwdriver to remove the seven 7 mm screws securing the back case.
      Ask FixBot
    2. Dell Latitude 3190 Keyboard Replacement: step 2, image 1 of 3 Dell Latitude 3190 Keyboard Replacement: step 2, image 2 of 3 Dell Latitude 3190 Keyboard Replacement: step 2, image 3 of 3
      • Using a plastic opening tool carefully separate the plastic base cover from the rest of the laptop.
      • Lift the bottom cover from the laptop.
      Ask FixBot
    1. Dell Latitude 3190 Keyboard Replacement, Battery: step 3, image 1 of 1
      • Locate the battery.
      Ask FixBot
    2. Dell Latitude 3190 Keyboard Replacement: step 4, image 1 of 3 Dell Latitude 3190 Keyboard Replacement: step 4, image 2 of 3 Dell Latitude 3190 Keyboard Replacement: step 4, image 3 of 3
      • Disconnect the battery cable located on the top of the battery.
      • Use the spudger and disconnect the battery cable.
      • Pull the cable out of the way.
      Ask FixBot
    3. Dell Latitude 3190 Keyboard Replacement: step 5, image 1 of 3 Dell Latitude 3190 Keyboard Replacement: step 5, image 2 of 3 Dell Latitude 3190 Keyboard Replacement: step 5, image 3 of 3
      • Use a Phillips #0 screwdriver to remove the three 3 mm screws from the battery.
      Ask FixBot
    4. Dell Latitude 3190 Keyboard Replacement: step 6, image 1 of 3 Dell Latitude 3190 Keyboard Replacement: step 6, image 2 of 3 Dell Latitude 3190 Keyboard Replacement: step 6, image 3 of 3
      • Pull the black battery tap upwards to remove the battery.
      • The battery adhesive is strong, do not be afraid to use force. You may need to use the spudger or opening tool as a wedge.
      Ask FixBot
    1. Dell Latitude 3190 Keyboard Replacement, Keyboard: step 7, image 1 of 2 Dell Latitude 3190 Keyboard Replacement, Keyboard: step 7, image 2 of 2
      • Use the spudger to release the small black tab locking down the connector by lightly pushing up on it.
      • Disconnect the keyboard cable from the connector on the system board.
      Ask FixBot
    2. Dell Latitude 3190 Keyboard Replacement: step 8, image 1 of 2 Dell Latitude 3190 Keyboard Replacement: step 8, image 2 of 2
      • Hold down the laptop securely while pushing into the two release holes using a spudger.
      • You may need to push harder than you think, you will feel it release.
      Ask FixBot
    3. Dell Latitude 3190 Keyboard Replacement: step 9, image 1 of 3 Dell Latitude 3190 Keyboard Replacement: step 9, image 2 of 3 Dell Latitude 3190 Keyboard Replacement: step 9, image 3 of 3
      • Turn the laptop over, so the keyboard is facing up
      • Pry the bottom of the keyboard using a spudger to the release the keyboard.
      • Slide the keyboard outwards, away from the computer, and lift the keyboard away from the computer.
      Ask FixBot
Haley Smith
313 Reputation
2 Guides authored
Gateway, Team 1-5, Saknee Fall 2021 Member of Gateway, Team 1-5, Saknee Fall 2021
GCC-SAKNEE-F21S1G5
3 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 31
Past 30 Days: 101
All Time: 2,275
