Dell Latitude 3190 Battery Replacement
    1. Dell Latitude 3190 Battery Replacement, Base Cover: step 1, image 1 of 2 Dell Latitude 3190 Battery Replacement, Base Cover: step 1, image 2 of 2
      • Use a Phillips #0 screwdriver to remove the seven 7 mm screws securing the back case.
      Ask FixBot
    2. Dell Latitude 3190 Battery Replacement: step 2, image 1 of 3 Dell Latitude 3190 Battery Replacement: step 2, image 2 of 3 Dell Latitude 3190 Battery Replacement: step 2, image 3 of 3
      • Using a plastic opening tool carefully separate the plastic base cover from the rest of the laptop.
      • Lift the bottom cover from the laptop.
      Ask FixBot
    1. Dell Latitude 3190 Battery Replacement, Battery: step 3, image 1 of 1
      • Locate the battery.
      Ask FixBot
    2. Dell Latitude 3190 Battery Replacement: step 4, image 1 of 3 Dell Latitude 3190 Battery Replacement: step 4, image 2 of 3 Dell Latitude 3190 Battery Replacement: step 4, image 3 of 3
      • Disconnect the battery cable located on the top of the battery.
      • Use the spudger and disconnect the battery cable.
      • Pull the cable out of the way.
      Ask FixBot
    3. Dell Latitude 3190 Battery Replacement: step 5, image 1 of 3 Dell Latitude 3190 Battery Replacement: step 5, image 2 of 3 Dell Latitude 3190 Battery Replacement: step 5, image 3 of 3
      • Use a Phillips #0 screwdriver to remove the three 3 mm screws from the battery.
      Ask FixBot
    4. Dell Latitude 3190 Battery Replacement: step 6, image 1 of 3 Dell Latitude 3190 Battery Replacement: step 6, image 2 of 3 Dell Latitude 3190 Battery Replacement: step 6, image 3 of 3
      • Pull the black battery tap upwards to remove the battery.
      • The battery adhesive is strong, do not be afraid to use force. You may need to use the spudger or opening tool as a wedge.
      Ask FixBot
2 other people completed this guide.
Daniel Tzunum
256 Reputation
2 Guides authored
Gateway, Team 1-5, Saknee Fall 2021 Member of Gateway, Team 1-5, Saknee Fall 2021
GCC-SAKNEE-F21S1G5
3 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 29
Past 30 Days: 113
All Time: 3,430
