Dell Latitude 3189 SSD Replacement
    1. Dell Latitude 3189 SSD Replacement, Lower Case: step 1, image 1 of 2 Dell Latitude 3189 SSD Replacement, Lower Case: step 1, image 2 of 2
      • Before beginning, power off and unplug the device.
      • Use a Phillips screwdriver to loosen the seven captive screws that secure the lower case.
      Ask FixBot
    2. Dell Latitude 3189 SSD Replacement: step 2, image 1 of 3 Dell Latitude 3189 SSD Replacement: step 2, image 2 of 3 Dell Latitude 3189 SSD Replacement: step 2, image 3 of 3
      • Insert a nylon spudger between the lower case and chassis at the two hinge spaces on the back side of the laptop and pry up the lower case.
      • Do not use metal items to pry the base cover off, like a screwdriver, as it could slip and damage internal components.
      • Avoid prying at the ports.
      Ask FixBot
    3. Dell Latitude 3189 SSD Replacement: step 3, image 1 of 2 Dell Latitude 3189 SSD Replacement: step 3, image 2 of 2
      • Grip and lift the lower case up and away.
      • If you feel any significant resistance, double check that all of the screws are loosened.
      Ask FixBot
    4. Dell Latitude 3189 SSD Replacement: step 4, image 1 of 3 Dell Latitude 3189 SSD Replacement: step 4, image 2 of 3 Dell Latitude 3189 SSD Replacement: step 4, image 3 of 3
      • Before performing any operations within the laptop, unplug the battery.
      • Pull the white battery connector directly out of its motherboard port.
      • Do not pull on the wires.
      Ask FixBot
    1. Dell Latitude 3189 SSD Replacement, SSD: step 5, image 1 of 2 Dell Latitude 3189 SSD Replacement, SSD: step 5, image 2 of 2
      • Use a Phillips screwdriver to remove the single 3.2 mm screw that secures the SSD.
      • The SSD will pop up a few millimeters; this is normal.
      Ask FixBot
    2. Dell Latitude 3189 SSD Replacement: step 6, image 1 of 1
      • Gently pull the SSD out of its socket, maintaining the same angle that it flipped up to.
      • Do not pull directly up on the SSD after the screw is removed as you could damage the SSD and/or the connector.
      Ask FixBot
3 other people completed this guide.
Maximus
198 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 27
Past 30 Days: 79
All Time: 870
