Dell Latitude 3150 SD Card Reader Replacement
    1. Dell Latitude 3150 SD Card Reader Replacement, Battery: step 1, image 1 of 3 Dell Latitude 3150 SD Card Reader Replacement, Battery: step 1, image 2 of 3 Dell Latitude 3150 SD Card Reader Replacement, Battery: step 1, image 3 of 3
      • Remove the seven  5 mm screws using a Phillips #1 screwdriver.
      • Pry the back open with a plastic opening tool, working around the edges until all the retaining clips are disengaged.
      Ask FixBot
    2. Dell Latitude 3150 SD Card Reader Replacement: step 2, image 1 of 3 Dell Latitude 3150 SD Card Reader Replacement: step 2, image 2 of 3 Dell Latitude 3150 SD Card Reader Replacement: step 2, image 3 of 3
      • Remove the two Phillips 3 mm screws connected to the battery using a Phillips #1 screwdriver.
      • Carefully lift the battery and unplug the battery cable from the device.
      • Remove the battery from the laptop.
      Ask FixBot
    1. Dell Latitude 3150 SD Card Reader Replacement, SD Card Reader: step 3, image 1 of 1
      • Using the metal spudger, remove the tape from the SD card reader.
      Ask FixBot
    2. Dell Latitude 3150 SD Card Reader Replacement: step 4, image 1 of 1
      • Use the soldering iron to heat the soldered wires around the SD card reader and carefully lift the reader.
      • The soldering iron is extremely hot. Maintain caution.
      Ask FixBot
    3. Dell Latitude 3150 SD Card Reader Replacement: step 5, image 1 of 2 Dell Latitude 3150 SD Card Reader Replacement: step 5, image 2 of 2
      • Remove the SD card reader from the laptop.
      Ask FixBot
Kohl Taylor
668 Reputation
5 Guides authored
Texas Tech, Team 2-3, Johansen Fall 2025 Member of Texas Tech, Team 2-3, Johansen Fall 2025
TTU-JOHANSEN-F25S2G3
5 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 9
Past 30 Days: 60
All Time: 260
