Tools
Introduction
Go to step 1 ↓If your Dell Latitude 3150 becomes slow, unresponsive, or jitters unexpectedly, it might be time to replace the RAM. Random-access memory (RAM) is a crucial part of the device that allows quick access and short-term storage. Replacing it yourself is an affordable option and can be done quickly with the right tools and careful handling.
Remove the seven  5 mm screws using a Phillips #1 screwdriver.
Pry the back open with a plastic opening tool, working around the edges until all the retaining clips are disengaged.
Using the metal spudger, push the pins on the sides of the RAM out.
The RAM will pop out; carefully remove it from the laptop.
