Dell Latitude 3150 Keyboard Replacement
    1. Dell Latitude 3150 Keyboard Replacement, Battery: step 1, image 1 of 3 Dell Latitude 3150 Keyboard Replacement, Battery: step 1, image 2 of 3 Dell Latitude 3150 Keyboard Replacement, Battery: step 1, image 3 of 3
      • Remove the seven  5 mm screws using a Phillips #1 screwdriver.
      • Pry the back open with a plastic opening tool, working around the edges until all the retaining clips are disengaged.
      Ask FixBot
    2. Dell Latitude 3150 Keyboard Replacement: step 2, image 1 of 3 Dell Latitude 3150 Keyboard Replacement: step 2, image 2 of 3 Dell Latitude 3150 Keyboard Replacement: step 2, image 3 of 3
      • Remove the two Phillips 3 mm screws connected to the battery using a Phillips #1 screwdriver.
      • Carefully lift the battery and unplug the battery cable from the device.
      • Remove the battery from the laptop.
      Ask FixBot
    1. Dell Latitude 3150 Keyboard Replacement, Keyboard: step 3, image 1 of 1
      • Using an opening pick, carefully pry up and unsnap the keyboard bezel.
      Ask FixBot
    2. Dell Latitude 3150 Keyboard Replacement: step 4, image 1 of 1
      • Using the Phillips #1 screwdriver, remove the five 3mm screws.
      Ask FixBot
    3. Dell Latitude 3150 Keyboard Replacement: step 5, image 1 of 2 Dell Latitude 3150 Keyboard Replacement: step 5, image 2 of 2
      • Using the metal spudger, lift the safety clip and gently disconnect the keyboard cable connector.
      Ask FixBot
    4. Dell Latitude 3150 Keyboard Replacement: step 6, image 1 of 2 Dell Latitude 3150 Keyboard Replacement: step 6, image 2 of 2
      • Lift the keyboard and remove it from the laptop.
      Ask FixBot
Kohl Taylor
668 Reputation
5 Guides authored
Texas Tech, Team 2-3, Johansen Fall 2025 Member of Texas Tech, Team 2-3, Johansen Fall 2025
TTU-JOHANSEN-F25S2G3
5 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 53
All Time: 225
