Up to 20% off select tools
Dell Inspiron n5110 Memory Module Replacement
Views: 1.1K
View statistics:
Past 24 Hours:
6
Past 7 Days:
13
Past 30 Days:
55
All Time:
1,078
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 - 45 seconds
Difficulty: Very easy
Community-Contributed Guide
Tools
Introduction
Go to step 1 ↓
In this guide, we will be showing you how to remove and replace the Memory Modules.
      • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in "Before You Begin".
      • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
      • CAUTION: To prevent damage to the memory module connector, do not use tools to spread the memory module securing clips.
      Ask FixBot
    1. Dell Inspiron n5110 Memory Module Replacement, Popping up the Memory Module: step 2, image 1 of 2 Dell Inspiron n5110 Memory Module Replacement, Popping up the Memory Module: step 2, image 2 of 2
      • Use your fingertips to carefully spread apart the securing clips on each end of the memory-module connector until the memory module pops up.
      Ask FixBot
    2. Dell Inspiron n5110 Memory Module Replacement, Remove the Memory Module: step 3, image 1 of 1
      • Remove the memory module from the memory-module connector.
      Ask FixBot
    3. Dell Inspiron n5110 Memory Module Replacement, Align the Notch: step 4, image 1 of 2 Dell Inspiron n5110 Memory Module Replacement, Align the Notch: step 4, image 2 of 2
      • Align the notch in the NEW memory module with the tab in the memory-module connector.
      Ask FixBot
    4. Dell Inspiron n5110 Memory Module Replacement, Sliding the Module: step 5, image 1 of 1
      • Slide the memory module firmly into the slot at a 45-degree angle, and press the memory module down until it clicks into place. If you do not hear the click, remove the memory module and reinstall it.
      • NOTE: If the memory module is not installed properly, the computer may not boot.
      Ask FixBot
Finish Line
Author
with
Terrence15
80,173 Reputation
441 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
45 Members
12,349 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 13
Past 30 Days: 55
All Time: 1,078
