Dell Inspiron n5110 Display Assembly Replacement
    1. Dell Inspiron n5110 Display Assembly Replacement, Remove the Screws: step 1, image 1 of 1
      • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in "Before You Begin".
      • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
      • Remove the two screws that secure the display assembly to the computer base.
      Ask FixBot
    2. Dell Inspiron n5110 Display Assembly Replacement, Disconnecting the Display Cable: step 2, image 1 of 1
      • Disconnect the display cable and touch-screen cable from the system-board connectors.
      • NOTE: The touch-screen board is optional and may not be present in your computer.
      Ask FixBot
    3. Dell Inspiron n5110 Display Assembly Replacement, Note the Routing: step 3, image 1 of 1
      • Note the routing of the Mini-Card antenna cables and remove the cables from the routing guides.
      Ask FixBot
    4. Dell Inspiron n5110 Display Assembly Replacement, Remove the Screws: step 4, image 1 of 1
      • Remove the four screws that secure the display assembly to the computer base.
      Ask FixBot
    5. Dell Inspiron n5110 Display Assembly Replacement, Lifting the Display Assembly.: step 5, image 1 of 1
      • Lift the display assembly off the computer base.
      Ask FixBot
    6. Dell Inspiron n5110 Display Assembly Replacement, Placing the Display Assembly: step 6, image 1 of 1
      • Place the NEW display assembly in position and replace the four screws that secure the display assembly to the computer base.
      Ask FixBot
    7. Dell Inspiron n5110 Display Assembly Replacement, Route the Cables: step 7, image 1 of 1
      • Route the Mini-Card antenna cables through the routing guides.
      Ask FixBot
    8. Dell Inspiron n5110 Display Assembly Replacement, Connect the Display Cable: step 8, image 1 of 1
      • Connect the display cable and touch-screen cable to the connectors on the system board.
      Ask FixBot
    9. Dell Inspiron n5110 Display Assembly Replacement, Replace the Screws: step 9, image 1 of 1
      • Replace the two screws that secure the display assembly to the computer base.
      Ask FixBot
Finish Line
3 other people completed this guide.
Terrence15
80,143 Reputation
441 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
45 Members
12,349 Guides authored
1 Guide Comment
can someone help me , i have the Dell Inspiron N5110 , the display was broken but has worked for long time and one time has not work anymore and the laptop peeps 8 times every 3-5 sec, and i removed the screen and tried to connecte it to external screen but also nothing happen and still peeping 8 times , anyone can help?
Khaled Alsheikh - Reply Share
Past 24 Hours: 5
Past 7 Days: 27
Past 30 Days: 78
All Time: 2,989
