Dell Inspiron One 2020 Hard Drive Replacement
  1. Dell Inspiron One 2020 Hard Drive Replacement, Back Cover: step 1, image 1 of 3 Dell Inspiron One 2020 Hard Drive Replacement, Back Cover: step 1, image 2 of 3 Dell Inspiron One 2020 Hard Drive Replacement, Back Cover: step 1, image 3 of 3
    • Place the all in one computer face down on a soft, clean surface to avoid scratching the front.
    • Press the tab on the stand cover and lift up.
    Ask FixBot
  2. Dell Inspiron One 2020 Hard Drive Replacement: step 2, image 1 of 3 Dell Inspiron One 2020 Hard Drive Replacement: step 2, image 2 of 3 Dell Inspiron One 2020 Hard Drive Replacement: step 2, image 3 of 3
    • Remove the four phillips screws that attach the stand to the computer.
    • Tilt the stand up and out.
    Ask FixBot
  3. Dell Inspiron One 2020 Hard Drive Replacement: step 3, image 1 of 3 Dell Inspiron One 2020 Hard Drive Replacement: step 3, image 2 of 3 Dell Inspiron One 2020 Hard Drive Replacement: step 3, image 3 of 3
    • Starting from the optical drive, pry the back cover up with a plastic spudger.
    • The cover is held in place by fragile plastic clips. Careful to not break them.
    Ask FixBot
  4. Dell Inspiron One 2020 Hard Drive Replacement, Hard Drive: step 4, image 1 of 2 Dell Inspiron One 2020 Hard Drive Replacement, Hard Drive: step 4, image 2 of 2
    • Remove the three screws that hold the hard drive cage to the chassis.
    Ask FixBot
  5. Dell Inspiron One 2020 Hard Drive Replacement: step 5, image 1 of 2 Dell Inspiron One 2020 Hard Drive Replacement: step 5, image 2 of 2
    • Slide the hard drive cage out slightly to access and remove the power and SATA cable.
    • There isn't much slack in these cables, so don't slide the hard drive cage to far.
    • The power and SATA cables are connected together. On most other computers, these connectors are separate.
    • Lift the hard drive cage out.
    Ask FixBot
  6. Dell Inspiron One 2020 Hard Drive Replacement: step 6, image 1 of 3 Dell Inspiron One 2020 Hard Drive Replacement: step 6, image 2 of 3 Dell Inspiron One 2020 Hard Drive Replacement: step 6, image 3 of 3
    • Remove the four screws (two on each side) that attach the hard drive cage to the hard drive.
    • Lift the hard drive cage off the hard drive.
    Ask FixBot
35 other people completed this guide.
Tyler
5,088 Reputation
16 Guides authored
TechForce Member of TechForce
Business
2 Members
29 Guides authored
3 Guide Comments
Thanks for this info this is very useful
Thank you once again
Ketan Valsangkar - Reply Share
Good Job, short and sweet and easy to follow
schmidtrg - Reply Share
Really useful information thank you.
Jessie Colon - Reply Share
Past 24 Hours: 2
Past 7 Days: 20
Past 30 Days: 94
All Time: 37,690
