Dell Inspiron N5050 RAM Replacement
    1. Dell Inspiron N5050 RAM Replacement, Battery: step 1, image 1 of 1
      • Flip your laptop over to view the bottom and the two locks.
      Ask FixBot
    2. Dell Inspiron N5050 RAM Replacement: step 2, image 1 of 1
      • Slide the two locks away from each other.
      • Sliding these locks will loosen the battery to allow removal.
      Ask FixBot
    3. Dell Inspiron N5050 RAM Replacement: step 3, image 1 of 2 Dell Inspiron N5050 RAM Replacement: step 3, image 2 of 2
      • Pull the battery out of the laptop.
      • Your laptop's battery should be completely removed.
      Ask FixBot
    1. Dell Inspiron N5050 RAM Replacement, RAM: step 4, image 1 of 1
      • Remove the eleven 5mm palmrest screws from the bottom of the laptop with a Phillips #PH00 screw.
      • Remove the two 3mm hard drive screws from the bottom of the laptop with a Phillips #PH00 screw.
      Ask FixBot
    2. Dell Inspiron N5050 RAM Replacement: step 5, image 1 of 2 Dell Inspiron N5050 RAM Replacement: step 5, image 2 of 2
      • Flip over and open the laptop to view the keyboard.
      • Use a plastic opening tool to press down on four clips, one by one.
      • Press down on the clips and pull the tool towards you to pry the keyboard loose.
      • The four clips are above the Esc, F6, F11, and Delete keys.
      Ask FixBot
    3. Dell Inspiron N5050 RAM Replacement: step 6, image 1 of 3 Dell Inspiron N5050 RAM Replacement: step 6, image 2 of 3 Dell Inspiron N5050 RAM Replacement: step 6, image 3 of 3
      • Remove the keyboard carefully.
      • Make sure to lift the keyboard gently, because a cable is connected to the back.
      • Flip the keyboard over to find the keyboard cable.
      • Pull the cable labeled "UP" out to disconnect it from the laptop.
      Ask FixBot
    4. Dell Inspiron N5050 RAM Replacement: step 7, image 1 of 3 Dell Inspiron N5050 RAM Replacement: step 7, image 2 of 3 Dell Inspiron N5050 RAM Replacement: step 7, image 3 of 3
      • Find the RAM and pull apart the two clips.
      • After pulling apart both clips, the RAM component will snap up.
      Ask FixBot
    5. Dell Inspiron N5050 RAM Replacement: step 8, image 1 of 2 Dell Inspiron N5050 RAM Replacement: step 8, image 2 of 2
      • Remove the RAM.
      Ask FixBot
9 other people completed this guide.
1 Guide Comment
Thanks Kristy,
I was breath new life back into an old laptop and re-purpose after upgrading the RAM.
jason acn - Reply Share
Past 24 Hours: 7
Past 7 Days: 34
Past 30 Days: 131
All Time: 3,274
