Up to 20% off select tools
Dell Inspiron N5030 RAM Replacement
Views: 6.5K
View statistics:
Past 24 Hours:
4
Past 7 Days:
25
Past 30 Days:
100
All Time:
6,462
Comments: 12
9 comments on steps, 3 guide comments.
Go to guide comments
Completed: 5
5 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 - 15 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
If you want to upgrade your computer by putting in new RAM, or if you need to replace your RAM with new boards, use this guide to learn how to do it.
    1. Dell Inspiron N5030 RAM Replacement, Battery: step 1, image 1 of 2 Dell Inspiron N5030 RAM Replacement, Battery: step 1, image 2 of 2
      • Turn the computer over on its back so the battery compartment faces towards you.
      • Place your fingers on the small buttons with arrows pointing outwards.
      • Push and slide the buttons outward to unlock the battery compartment.
      Ask FixBot
    2. Dell Inspiron N5030 RAM Replacement: step 2, image 1 of 2 Dell Inspiron N5030 RAM Replacement: step 2, image 2 of 2
      • Grab the battery and pull it towards yourself.
      • Remove the battery.
      Ask FixBot
    1. Dell Inspiron N5030 RAM Replacement, Keyboard: step 3, image 1 of 1
      • Use a Phillips #0 screwdriver to unscrew the sixteen 0.6 mm screws on the back panel.
      Ask FixBot
    2. Dell Inspiron N5030 RAM Replacement: step 4, image 1 of 1
      • Flip over the laptop and open it so that the screen faces you.
      Ask FixBot
    3. Dell Inspiron N5030 RAM Replacement: step 5, image 1 of 1
      • Use the plastic opening tool and your fingers to pry off the top panel.
      • Pry the panel off starting at any one of the corners and then continue around the edges of the computer.
      Ask FixBot
    4. Dell Inspiron N5030 RAM Replacement: step 6, image 1 of 1
      • Be careful when lifting off the keyboard panel. There are multiple delicate cables connecting the panel to the motherboard.
      • Pull up on the blue plastic tab connected by the white strip to unhook the keyboard panel from the motherboard.
      Ask FixBot
    5. Dell Inspiron N5030 RAM Replacement: step 7, image 1 of 1
      • Flip up the small locking flap on the keyboard cable ZIF socket and disconnect the keyboard ribbon cable.
      Ask FixBot
    6. Dell Inspiron N5030 RAM Replacement: step 8, image 1 of 1
      • Pull up on the wire tab with the blue, white, black, and red wires to detach the speakers from the motherboard.
      Ask FixBot
    7. Dell Inspiron N5030 RAM Replacement: step 9, image 1 of 1
      • Remove the top keyboard panel.
      Ask FixBot
    1. Dell Inspiron N5030 RAM Replacement, RAM: step 10, image 1 of 1
      • Place your fingers on the two metal tabs on the edges of the RAM.
      • Push on the tabs in the opposite direction.
      • The top RAM board will pop up after you push on the metal tabs.
      Ask FixBot
    2. Dell Inspiron N5030 RAM Replacement: step 11, image 1 of 1
      • Pull the top RAM board out with your fingers.
      Ask FixBot
    3. Dell Inspiron N5030 RAM Replacement: step 12, image 1 of 3 Dell Inspiron N5030 RAM Replacement: step 12, image 2 of 3 Dell Inspiron N5030 RAM Replacement: step 12, image 3 of 3
      • Repeat the above RAM board steps for the second RAM board.
      Ask FixBot
5 other people completed this guide.
Author
with
Rodrigo Perez
230 Reputation
1 Guide authored
Cal Poly, Team 10-59, Amido Spring 2014 Member of Cal Poly, Team 10-59, Amido Spring 2014
CPSU-AMIDO-S14S10G59
4 Members
60 Guides authored
3 Guide Comments
Looking at the Dell service manual. You dont need to remove any screws, but only the keyboard, and if your careful you dont need to remove the ribbon cable. Its all in the service manual you can download free from Dell.
swestonj - Reply Share
swestonj is incorrect. The manual clearly states that you must remove the screws:
Service Manual
Removing the Keyboard
1. Follow the instructions in Before You Begin.
2. Remove the battery (see Removing the Battery).
3. Remove the two screws that secure the keyboard to the computer base.
etc.
mike - Reply Share
зависит от целей. озу можно поменять не разбирая всё. а вот пзу придется все разобрать. я так и не понял сьёмный тут проц или припаян. вроде есть защелка
артемий Александровна троицкий - Reply Share
Past 24 Hours: 4
Past 7 Days: 25
Past 30 Days: 100
All Time: 6,462
