Dell Inspiron N5030 Keyboard Replacement
    1. Dell Inspiron N5030 Keyboard Replacement, Battery: step 1, image 1 of 2 Dell Inspiron N5030 Keyboard Replacement, Battery: step 1, image 2 of 2
      • Turn the computer over on its back so the battery compartment faces towards you.
      • Place your fingers on the small buttons with arrows pointing outwards.
      • Push and slide the buttons outward to unlock the battery compartment.
      Ask FixBot
    2. Dell Inspiron N5030 Keyboard Replacement: step 2, image 1 of 2 Dell Inspiron N5030 Keyboard Replacement: step 2, image 2 of 2
      • Grab the battery and pull it towards yourself.
      • Remove the battery.
      Ask FixBot
    1. Dell Inspiron N5030 Keyboard Replacement, Keyboard: step 3, image 1 of 1
      • Use a Phillips #0 screwdriver to unscrew the sixteen 0.6 mm screws on the back panel.
      Ask FixBot
    2. Dell Inspiron N5030 Keyboard Replacement: step 4, image 1 of 1
      • Flip over the laptop and open it so that the screen faces you.
      Ask FixBot
    3. Dell Inspiron N5030 Keyboard Replacement: step 5, image 1 of 1
      • Use the plastic opening tool and your fingers to pry off the top panel.
      • Pry the panel off starting at any one of the corners and then continue around the edges of the computer.
      Ask FixBot
    4. Dell Inspiron N5030 Keyboard Replacement: step 6, image 1 of 1
      • Be careful when lifting off the keyboard panel. There are multiple delicate cables connecting the panel to the motherboard.
      • Pull up on the blue plastic tab connected by the white strip to unhook the keyboard panel from the motherboard.
      Ask FixBot
    5. Dell Inspiron N5030 Keyboard Replacement: step 7, image 1 of 1
      • Flip up the small locking flap on the keyboard cable ZIF socket and disconnect the keyboard ribbon cable.
      Ask FixBot
    6. Dell Inspiron N5030 Keyboard Replacement: step 8, image 1 of 1
      • Pull up on the wire tab with the blue, white, black, and red wires to detach the speakers from the motherboard.
      Ask FixBot
    7. Dell Inspiron N5030 Keyboard Replacement: step 9, image 1 of 1
      • Remove the top keyboard panel.
      Ask FixBot
5 other people completed this guide.
Gunnar Salazar
128 Reputation
1 Guide authored
Cal Poly, Team 10-59, Amido Spring 2014 Member of Cal Poly, Team 10-59, Amido Spring 2014
CPSU-AMIDO-S14S10G59
4 Members
60 Guides authored
2 Guide Comments
What if i broke the blue ribbons connection to the keyboard
oibrahimopeyemi - Reply Share
This solution is quite troublesome and does not explain how to disconnect / re-connect the wide flat keyboard cable. For a simpler solution see :
https://www.youtube.com/watch?v=jWuGb9AA...
Agropecuaria El Sinu - Reply Share
Past 24 Hours: 7
Past 7 Days: 31
Past 30 Days: 99
All Time: 3,458
