Dell Inspiron N4110 Screen Replacement
    1. Dell Inspiron N4110 Screen Replacement, Battery: step 1, image 1 of 1
      • Make sure the laptop is off and unplugged before starting this step.
      • Locate the battery on the underside of the laptop.
      • Push the two battery clips following the direction of the arrows.
      Ask FixBot
    2. Dell Inspiron N4110 Screen Replacement: step 2, image 1 of 1
      • Push upward from the base of the battery.
      Ask FixBot
    3. Dell Inspiron N4110 Screen Replacement: step 3, image 1 of 1
      • Pull battery away from computer until it is fully removed.
      Ask FixBot
    1. Dell Inspiron N4110 Screen Replacement, Screen: step 4, image 1 of 3 Dell Inspiron N4110 Screen Replacement, Screen: step 4, image 2 of 3 Dell Inspiron N4110 Screen Replacement, Screen: step 4, image 3 of 3
      • Use your hands to remove the plastic cover from around the screen.
      • This can seem difficult, but it can be done.
      Ask FixBot
    2. Dell Inspiron N4110 Screen Replacement: step 5, image 1 of 2 Dell Inspiron N4110 Screen Replacement: step 5, image 2 of 2
      • Unscrew the two 2.5x4 mm screws from the top of the screen.
      Ask FixBot
    3. Dell Inspiron N4110 Screen Replacement: step 6, image 1 of 2 Dell Inspiron N4110 Screen Replacement: step 6, image 2 of 2
      • Loosen the four 2.5x4 mm screws from the base of the screen.
      • This will allow the screen to lift from inside the top of the case.
      Ask FixBot
    4. Dell Inspiron N4110 Screen Replacement: step 7, image 1 of 3 Dell Inspiron N4110 Screen Replacement: step 7, image 2 of 3 Dell Inspiron N4110 Screen Replacement: step 7, image 3 of 3
      • Unscrew the four 2x3 mm screws from the two sides on both the top and bottom.
      Ask FixBot
    5. Dell Inspiron N4110 Screen Replacement: step 8, image 1 of 2 Dell Inspiron N4110 Screen Replacement: step 8, image 2 of 2
      Tool used on this step:
      Buy
      • Use tweezers to peel the webcam away from the top of the laptop.
      • The webcam is only held in place by a webcam, this is easy to pull away from the screen.
      Ask FixBot
    6. Dell Inspiron N4110 Screen Replacement: step 9, image 1 of 3 Dell Inspiron N4110 Screen Replacement: step 9, image 2 of 3 Dell Inspiron N4110 Screen Replacement: step 9, image 3 of 3
      • Lift the adhesive flap from the cord that connects the computer to the screen.
      • You can then disconnect the cord from the screen.
      Ask FixBot
    7. Dell Inspiron N4110 Screen Replacement: step 10, image 1 of 1
      • The screen can now be fully removed from the computer.
      Ask FixBot
Abigail Keith
559 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 20
Past 30 Days: 61
All Time: 1,837
