Dell Inspiron N4110 RAM Replacement
    1. Dell Inspiron N4110 RAM Replacement, Battery: step 1, image 1 of 1
      • Make sure the laptop is off and unplugged before starting this step.
      • Locate the battery on the underside of the laptop.
      • Push the two battery clips following the direction of the arrows.
      Ask FixBot
    2. Dell Inspiron N4110 RAM Replacement: step 2, image 1 of 1
      • Push upward from the base of the battery.
      Ask FixBot
    3. Dell Inspiron N4110 RAM Replacement: step 3, image 1 of 1
      • Pull battery away from computer until it is fully removed.
      Ask FixBot
    1. Dell Inspiron N4110 RAM Replacement, RAM: step 4, image 1 of 2 Dell Inspiron N4110 RAM Replacement, RAM: step 4, image 2 of 2
      • Locate and unscrew the one 2.5x5 mm screw on the cover.
      • The screw does not detach from the cover. Make sure the screw is fully unscrewed before attempting to remove the cover.
      Ask FixBot
    2. Dell Inspiron N4110 RAM Replacement: step 5, image 1 of 2 Dell Inspiron N4110 RAM Replacement: step 5, image 2 of 2
      • Remove RAM cover from the laptop.
      Ask FixBot
    3. Dell Inspiron N4110 RAM Replacement: step 6, image 1 of 2 Dell Inspiron N4110 RAM Replacement: step 6, image 2 of 2
      • Use your fingers to separate the two metal clips from the RAM.
      • The RAM will lift up when properly separated. Do not force the RAM out of the clips.
      Ask FixBot
    4. Dell Inspiron N4110 RAM Replacement: step 7, image 1 of 1
      • Remove the RAM from the computer.
      • Be careful as to not touch the metal on the bottom of the RAM. This can cause damage.
      • The RAM should be placed on a non-conductive surface.
      Ask FixBot
3 other people completed this guide.
Olivia
818 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 24
Past 30 Days: 72
All Time: 1,308
