Dell Inspiron N4010 Screen Replacement
    1. Dell Inspiron N4010 Screen Replacement, Screen: step 1, image 1 of 3 Dell Inspiron N4010 Screen Replacement, Screen: step 1, image 2 of 3 Dell Inspiron N4010 Screen Replacement, Screen: step 1, image 3 of 3
      • Use a plastic opening tool to remove the screen bezel.
      Ask FixBot
    2. Dell Inspiron N4010 Screen Replacement: step 2, image 1 of 3 Dell Inspiron N4010 Screen Replacement: step 2, image 2 of 3 Dell Inspiron N4010 Screen Replacement: step 2, image 3 of 3
      • Using the #0 Philips head, unscrew the screen bracket from the base of the laptop.
      Ask FixBot
    3. Dell Inspiron N4010 Screen Replacement: step 3, image 1 of 3 Dell Inspiron N4010 Screen Replacement: step 3, image 2 of 3 Dell Inspiron N4010 Screen Replacement: step 3, image 3 of 3
      • Remove the plastic seal located on the back of the screen to expose the ribbon connector.
      • Unplug the ribbon cable from the screen.
      • Be careful when unplugging the cable. Make sure you peel the tape all the way back before disconnecting.
      Ask FixBot
    4. Dell Inspiron N4010 Screen Replacement: step 4, image 1 of 3 Dell Inspiron N4010 Screen Replacement: step 4, image 2 of 3 Dell Inspiron N4010 Screen Replacement: step 4, image 3 of 3
      • Use the #0 Philips head to remove the six screws on either sides of the screen frame.
      • Remove the metal frame from the screen.
      Ask FixBot
2 other people completed this guide.
Jonathan Sellier
952 Reputation
7 Guides authored
USF Tampa, Team S13-G5, Boczar Fall 2017 Member of USF Tampa, Team S13-G5, Boczar Fall 2017
USFT-BOCZAR-F17S13G5
5 Members
108 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 31
Past 30 Days: 115
All Time: 1,972
