Introduction
Most internal components of the Dell Inspiron N4010 are located beneath the palm rest. This guide shows how to remove and replace the palm rest assembly, which is often required to access internal parts.
Removing the palm rest provides access to key components, but exposing internal hardware also increases the risk of damage. Before starting, confirm that the part you need to access is located beneath the palm rest.
Using the #0 Philips head, unscrew the indicated screw.
Carefully pull the RAM cover up and away.
Remove the indicated 5.7mm screws.
Remove the smaller 3mm screws from underneath the battery compartment.
