Dell Inspiron N4010 Hard Drive Replacement
  1. Dell Inspiron N4010 Hard Drive Replacement, Remove the Screws: step 1, image 1 of 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in Before You Begin.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • Remove the two screws that secure the hard-drive assembly to the system board.
    Ask FixBot
  2. Dell Inspiron N4010 Hard Drive Replacement, Sliding the Hard-Drive Assembly: step 2, image 1 of 1
    • Slide the hard-drive assembly to disconnect it from the connector on the system board.
    Ask FixBot
  3. Dell Inspiron N4010 Hard Drive Replacement, Lifting the Hard Drive Assembly: step 3, image 1 of 1
    • Lift the hard-drive assembly away from the system board.
    Ask FixBot
  4. Dell Inspiron N4010 Hard Drive Replacement, Remove the Screws: step 4, image 1 of 1
    • Remove the four screws that secure the hard-drive bracket to the hard drive.
    Ask FixBot
  5. Dell Inspiron N4010 Hard Drive Replacement, Lifting the Hard-Drive Bracket: step 5, image 1 of 1
    • Lift the hard-drive bracket off the hard drive.
    Ask FixBot
  6. Dell Inspiron N4010 Hard Drive Replacement, Align the Screw Holes: step 6, image 1 of 1
    • Align the screw holes on the hard-drive bracket with the screw holes on the NEW hard drive and replace the four screws.
    Ask FixBot
  7. Dell Inspiron N4010 Hard Drive Replacement, Sliding the Hard-Drive Assembly: step 7, image 1 of 1
    • Slide and push the hard-drive assembly to connect it to connector on the system board.
    Ask FixBot
  8. Dell Inspiron N4010 Hard Drive Replacement, Replace the Screws: step 8, image 1 of 1
    • Replace the two screws that secure the hard-drive assembly to the system board.
    Ask FixBot
Finish Line
Terrence15
80,125 Reputation
441 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
45 Members
2,003 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 25
All Time: 1,176
