Dell Inspiron N4010 Hard Disk Drive Replacement
    1. Dell Inspiron N4010 Hard Disk Drive Replacement, Battery: step 1, image 1 of 1
      • Make sure the laptop is not plugged into any wall outlets or the charger
      • Unlock the battery by sliding the right-hand switch to the right.
      Ask FixBot
    2. Dell Inspiron N4010 Hard Disk Drive Replacement: step 2, image 1 of 2 Dell Inspiron N4010 Hard Disk Drive Replacement: step 2, image 2 of 2
      • While holding the left-hand switch to the left position, pull the battery away from the laptop.
      Ask FixBot
    3. Dell Inspiron N4010 Hard Disk Drive Replacement: step 3, image 1 of 1
      • The battery is now fully removed and the laptop will not power on without it.
      Ask FixBot
    1. Dell Inspiron N4010 Hard Disk Drive Replacement, Keyboard: step 4, image 1 of 3 Dell Inspiron N4010 Hard Disk Drive Replacement, Keyboard: step 4, image 2 of 3 Dell Inspiron N4010 Hard Disk Drive Replacement, Keyboard: step 4, image 3 of 3
      • Using the #0 Philips head, unscrew the indicated screw.
      • Carefully pull the RAM cover up and away.
      Ask FixBot
    2. Dell Inspiron N4010 Hard Disk Drive Replacement: step 5, image 1 of 1
      • Unscrew the indicated 5.7mm screw beneath the RAM Cover.
      Ask FixBot
      • Remove another screw above the battery release tab
      Ask FixBot
    3. Dell Inspiron N4010 Hard Disk Drive Replacement: step 7, image 1 of 2 Dell Inspiron N4010 Hard Disk Drive Replacement: step 7, image 2 of 2
      • Using a thin plastic tool (such as a guitar pick or spudger) at the top of the keyboard just above the F7 key, gently pry the keyboard away.
      • Move the spudger to either end at the top of the keyboard to fully undo all plastic clips.
      Ask FixBot
    4. Dell Inspiron N4010 Hard Disk Drive Replacement: step 8, image 1 of 2 Dell Inspiron N4010 Hard Disk Drive Replacement: step 8, image 2 of 2
      • Carefully tip the keyboard upwards and pull it slightly away from the body of the laptop.
      • Be careful not to put stress on the ribbon cable below.
      Ask FixBot
    5. Dell Inspiron N4010 Hard Disk Drive Replacement: step 9, image 1 of 2 Dell Inspiron N4010 Hard Disk Drive Replacement: step 9, image 2 of 2
      • Carefully unclip the ribbon cable by tipping the keyboard towards the screen.
      • The keyboard is now completely disconnected.
      Ask FixBot
    1. Dell Inspiron N4010 Hard Disk Drive Replacement, Palm Rest Assembly: step 10, image 1 of 2 Dell Inspiron N4010 Hard Disk Drive Replacement, Palm Rest Assembly: step 10, image 2 of 2
      • Remove the indicated 5.7mm screws.
      • Remove the smaller 3mm screws from underneath the battery compartment.
      Ask FixBot
    2. Dell Inspiron N4010 Hard Disk Drive Replacement: step 11, image 1 of 2 Dell Inspiron N4010 Hard Disk Drive Replacement: step 11, image 2 of 2
      • With a plastic spudger, pry away the silver top cover from the black casing.
      • Move the tool to the right and left along the seams to fully disconnect the cover.
      Ask FixBot
    3. Dell Inspiron N4010 Hard Disk Drive Replacement: step 12, image 1 of 1
      • Disconnect the indicated ribbon cables underneath where the keyboard sits.
      Ask FixBot
    4. Dell Inspiron N4010 Hard Disk Drive Replacement: step 13, image 1 of 1
      • Lift the cover upwards and away from the body of the laptop, after removing the optical drive and unscrewing the three screws on the right.
      Ask FixBot
    1. Dell Inspiron N4010 Hard Disk Drive Replacement, Fan: step 14, image 1 of 2 Dell Inspiron N4010 Hard Disk Drive Replacement, Fan: step 14, image 2 of 2
      • Peel back the yellow tape to expose the ribbon connector.
      • Unplug the ribbon cable from the motherboard.
      Ask FixBot
    2. Dell Inspiron N4010 Hard Disk Drive Replacement: step 15, image 1 of 1
      • Unplug the 3-wire connector from the motherboard.
      Ask FixBot
    3. Dell Inspiron N4010 Hard Disk Drive Replacement: step 16, image 1 of 1
      • Unscrew the indicated 5.6mm screws with the #0 Phillips Head Screwdriver.
      Ask FixBot
    4. Dell Inspiron N4010 Hard Disk Drive Replacement: step 17, image 1 of 1
      • Remove the fan from the device.
      Ask FixBot
    1. Dell Inspiron N4010 Hard Disk Drive Replacement, Motherboard: step 18, image 1 of 2 Dell Inspiron N4010 Hard Disk Drive Replacement, Motherboard: step 18, image 2 of 2
      • Unscrew the two screws on the right hand speaker with the #0 Phillips Head.
      • Unplug the speaker connector from the motherboard.
      Ask FixBot
    2. Dell Inspiron N4010 Hard Disk Drive Replacement: step 19, image 1 of 1
      • Reaching under the daughter board, disconnect the connector.
      • It will be under the board in the area indicated.
      Ask FixBot
    3. Dell Inspiron N4010 Hard Disk Drive Replacement: step 20, image 1 of 1
      • Unscrew the indicated 5.6mm screws with a Phillips #0 screwdriver.
      Ask FixBot
    4. Dell Inspiron N4010 Hard Disk Drive Replacement: step 21, image 1 of 1
      • The motherboard can now be removed by pulling upwards, tilting it to the left of the laptop until the connectors clear the body of the laptop.
      Ask FixBot
    1. Dell Inspiron N4010 Hard Disk Drive Replacement, Hard Disk Drive: step 22, image 1 of 1
      • Unscrew the 6 Phillips head screws holding the hard drive to the motherboard with the #0 driver head.
      Ask FixBot
    2. Dell Inspiron N4010 Hard Disk Drive Replacement: step 23, image 1 of 2 Dell Inspiron N4010 Hard Disk Drive Replacement: step 23, image 2 of 2
      • Slide the hard drive towards the center of the motherboard.
      • The hard drive should come away from the motherboard.
      Ask FixBot
    3. Dell Inspiron N4010 Hard Disk Drive Replacement: step 24, image 1 of 1
      • Undo the 2 screws with the #0 Phillips head driver on either side of the hard drive assembly.
      Ask FixBot
    4. Dell Inspiron N4010 Hard Disk Drive Replacement: step 25, image 1 of 2 Dell Inspiron N4010 Hard Disk Drive Replacement: step 25, image 2 of 2
      • Slide the assembly off of the hard drive.
      Ask FixBot
5 other people completed this guide.
Jonathan Sellier
952 Reputation
7 Guides authored
USF Tampa, Team S13-G5, Boczar Fall 2017 Member of USF Tampa, Team S13-G5, Boczar Fall 2017
USFT-BOCZAR-F17S13G5
5 Members
108 Guides authored
7 Guide Comments
I hope somebody at Dell lost their job over this design.
Jason Northrup - Reply Share
hahaha i agree
Robert G - Reply Share
The N4010 is definitely a beautiful-looking set, but it’s sure a tough nut to crack when it’s time to repair something inside it, lol :-D
Terry McKean - Reply Share
A bunch of screws not listed have to be removed also they are in proximity of the cmos battery I imagine someone will damage their machine following this NOT GOOD! I signed up just to post this! Look for screws with the LETTER B they need removing before the board can come out! ifixit should screen their submissions better
ptooti - Reply Share
In step 20 we remove the screws
Jonathan Sellier - Reply Share
Past 24 Hours: 0
Past 7 Days: 13
Past 30 Days: 50
All Time: 8,663
