Up to 20% off select tools
Dell Inspiron Mini 1012 Screen Replacement
Views: 2.1K
View statistics:
Past 24 Hours:
2
Past 7 Days:
15
Past 30 Days:
86
All Time:
2,091
Comments: 1
1 comment on steps.
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 30 - 45 minutes
Difficulty: Moderate
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Tools
Introduction
Go to step 1 ↓
Step by step instructions on how to locate and remove screws and parts of the device to locate the screen, remove it, replace it with a new one, and put the device back together.
    1. Dell Inspiron Mini 1012 Screen Replacement, Screen: step 1, image 1 of 3 Dell Inspiron Mini 1012 Screen Replacement, Screen: step 1, image 2 of 3 Dell Inspiron Mini 1012 Screen Replacement, Screen: step 1, image 3 of 3
      • Remove the battery from the device for safety. Slide the two tabs on the bottom of the computer to the unlocked position, and gently lift up the battery.
      • Remove the two rubber pieces at the bottom of the screen and remove the screws located behind them.
      • Carefully remove the plastic casing from the device.
      Ask FixBot
    2. Dell Inspiron Mini 1012 Screen Replacement: step 2, image 1 of 3 Dell Inspiron Mini 1012 Screen Replacement: step 2, image 2 of 3 Dell Inspiron Mini 1012 Screen Replacement: step 2, image 3 of 3
      • Remove the four screws on each corner of the screen. Then remove the screws located on the side of the screen.
      • Carefully unplug the ribbon on the back of the screen.
      Ask FixBot
    3. Dell Inspiron Mini 1012 Screen Replacement: step 3, image 1 of 3 Dell Inspiron Mini 1012 Screen Replacement: step 3, image 2 of 3 Dell Inspiron Mini 1012 Screen Replacement: step 3, image 3 of 3
      • Place the new screen onto the device and plug the ribbon in.
      • Replace the screws on the side of the screen.
      Ask FixBot
    4. Dell Inspiron Mini 1012 Screen Replacement: step 4, image 1 of 3 Dell Inspiron Mini 1012 Screen Replacement: step 4, image 2 of 3 Dell Inspiron Mini 1012 Screen Replacement: step 4, image 3 of 3
      • Snap on the plastic screen cover and replace the two screws and the rubber pieces at the bottom of the screen.
      • Turn the computer over and put the battery back in.
      Ask FixBot
To reassemble your device, follow guide instructions.
4 other people completed this guide.
Author
with
sabinabarajas
402 Reputation
3 Guides authored
Gateway, Team 2-2, Kuhn Fall 2015 Member of Gateway, Team 2-2, Kuhn Fall 2015
GCC-KUHN-F15S2G2
1 Member
36 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 15
Past 30 Days: 86
All Time: 2,091
