Dell Inspiron Mini 1012 Keyboard Replacement
    1. Dell Inspiron Mini 1012 Keyboard Replacement, Keyboard: step 1, image 1 of 3 Dell Inspiron Mini 1012 Keyboard Replacement, Keyboard: step 1, image 2 of 3 Dell Inspiron Mini 1012 Keyboard Replacement, Keyboard: step 1, image 3 of 3
      • Unlock the two tabs on the bottom of the laptop.
      • Use your fingernail or a spudger to pull the battery pack out of the laptop.
      Ask FixBot
    2. Dell Inspiron Mini 1012 Keyboard Replacement: step 2, image 1 of 1
      • Remove the three screws with a Phillips #00 screwdriver.
      Ask FixBot
    3. Dell Inspiron Mini 1012 Keyboard Replacement: step 3, image 1 of 2 Dell Inspiron Mini 1012 Keyboard Replacement: step 3, image 2 of 2
      • Insert the spudger between the top of the keyboard and the laptop body.
      • Carefully pry the keyboard up.
      • Be gentle! You don't want to damage the laptops ribbon cable connector by pulling too hard.
      • It's not recommended to use a metal spudger for this repair as the photo shows. A regular nylon spudger will work just fine.
      Ask FixBot
    4. Dell Inspiron Mini 1012 Keyboard Replacement: step 4, image 1 of 2 Dell Inspiron Mini 1012 Keyboard Replacement: step 4, image 2 of 2
      • Unlock the connector to release the ribbon cable.
      • Carefully pull on the clear tab to remove the keyboard from the device.
      Ask FixBot
    5. Dell Inspiron Mini 1012 Keyboard Replacement: step 5, image 1 of 3 Dell Inspiron Mini 1012 Keyboard Replacement: step 5, image 2 of 3 Dell Inspiron Mini 1012 Keyboard Replacement: step 5, image 3 of 3
      • Take the new keyboard and insert the ribbon cable into the connector on the laptop.
      • Lay the keyboard back onto the device and gently snap it back into place.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order starting at step two.
sabinabarajas
402 Reputation
3 Guides authored
Gateway, Team 2-2, Kuhn Fall 2015 Member of Gateway, Team 2-2, Kuhn Fall 2015
GCC-KUHN-F15S2G2
1 Member
36 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 12
Past 30 Days: 39
All Time: 1,050
