Dell Inspiron Mini 1012 Battery Replacement
    1. Dell Inspiron Mini 1012 Battery Replacement, Battery: step 1, image 1 of 3 Dell Inspiron Mini 1012 Battery Replacement, Battery: step 1, image 2 of 3 Dell Inspiron Mini 1012 Battery Replacement, Battery: step 1, image 3 of 3
      • Turn the device over so the bottom is facing upwards.
      • Slide the two tabs beside the lock icons to the unlocked position.
      • Find the notch located in the center between the two tabs and lift up on the battery to remove it.
      • To replace the battery, align the three notches on the battery with the grooves on the device. Snap the battery back onto the device, and it will lock in place.
      Ask FixBot
To reassemble, place the new battery in the three slots. Lock the battery back in place.
sabinabarajas
402 Reputation
3 Guides authored
Gateway, Team 2-2, Kuhn Fall 2015 Member of Gateway, Team 2-2, Kuhn Fall 2015
GCC-KUHN-F15S2G2
1 Member
36 Guides authored
1 Guide Comment
So, I’ve installed the new battery and the mini 1012 won’t recognize or charge it. Now what?
complainingparty - Reply Share
Past 24 Hours: 3
Past 7 Days: 9
Past 30 Days: 42
All Time: 2,081
