Dell Inspiron Mini 10 Touchpad Replacement
    1. Dell Inspiron Mini 10 Touchpad Replacement, Battery: step 1, image 1 of 1
      • To prevent injury and loss of data, ensure the device is turned off.
      • Slide the release latches out toward the edges to unlock the battery.
      Ask FixBot
    2. Dell Inspiron Mini 10 Touchpad Replacement: step 2, image 1 of 1
      • Remove the battery by pulling it up and out.
      Ask FixBot
    1. Dell Inspiron Mini 10 Touchpad Replacement, Touchpad: step 3, image 1 of 2 Dell Inspiron Mini 10 Touchpad Replacement, Touchpad: step 3, image 2 of 2
      • Using a spudger, gently pry the palm rest off of the palm rest bracket.
      • Carefully remove the palm rest from the computer base to avoid damage to the palm rest.
      Ask FixBot
    2. Dell Inspiron Mini 10 Touchpad Replacement: step 4, image 1 of 1
      • Gently pull the touchpad cable off the palm rest bracket.
      • Lift the rest of the palm rest off the computer base.
      Ask FixBot
    3. Dell Inspiron Mini 10 Touchpad Replacement: step 5, image 1 of 3 Dell Inspiron Mini 10 Touchpad Replacement: step 5, image 2 of 3 Dell Inspiron Mini 10 Touchpad Replacement: step 5, image 3 of 3
      • Turn the palm rest assembly over.
      • Remove the four 3mm Phillips 0 screws that secure the touchpad module to the palm rest.
      • Gently lift the copper and silver foil squares on the touchpad.
      • Remove the touchpad from the palm rest.
      Ask FixBot
Angela Wild
107 Reputation
1 Guide authored
UW Tacoma, Team 1-4, Rose Fall 2016 Member of UW Tacoma, Team 1-4, Rose Fall 2016
UWT-ROSE-F16S1G4
4 Members
120 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 18
Past 30 Days: 99
All Time: 1,010
