Dell Inspiron Mini 10 Palm Rest Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
15
Past 30 Days:
81
All Time:
674
Comments: 2
2 comments on steps.
Completed: 0
Favorites: 0
Time Required: 2 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
This guide will show you how to remove the palm rest. This may be necessary in order to clean beneath the palm rest or to access the touchpad.
Tools
    1. Dell Inspiron Mini 10 Palm Rest Replacement, Battery: step 1, image 1 of 1
      • To prevent injury and loss of data, ensure the device is turned off.
      • Slide the release latches out toward the edges to unlock the battery.
      Ask FixBot
    2. Dell Inspiron Mini 10 Palm Rest Replacement: step 2, image 1 of 1
      • Remove the battery by pulling it up and out.
      Ask FixBot
    1. Dell Inspiron Mini 10 Palm Rest Replacement, Palm Rest: step 3, image 1 of 1
      • Using a prying tool, gently pry the palm rest off of the palm rest bracket. Start prying from one side and slowly work your way around.
      • Carefully remove the palm rest from the computer base since it is still connected by a cable and to avoid damage to the palm rest.
      Ask FixBot
    2. Dell Inspiron Mini 10 Palm Rest Replacement: step 4, image 1 of 1
      • Gently pull the touchpad cable off the palm rest bracket.
      • Lift the rest of the palm rest off the computer base.
      Ask FixBot
Bariso Shuba
270 Reputation
3 Guides authored
UW Tacoma, Team 1-4, Rose Fall 2016 Member of UW Tacoma, Team 1-4, Rose Fall 2016
UWT-ROSE-F16S1G4
4 Members
120 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 15
Past 30 Days: 81
All Time: 674
