Dell Inspiron Mini 10 Palm Rest Bracket Replacement
    1. Dell Inspiron Mini 10 Palm Rest Bracket Replacement, Battery: step 1, image 1 of 1
      • To prevent injury and loss of data, ensure the device is turned off.
      • Slide the release latches out toward the edges to unlock the battery.
      Ask FixBot
    2. Dell Inspiron Mini 10 Palm Rest Bracket Replacement: step 2, image 1 of 1
      • Remove the battery by pulling it up and out.
      Ask FixBot
    1. Dell Inspiron Mini 10 Palm Rest Bracket Replacement, Keyboard: step 3, image 1 of 1
      • Remove the three 8mm Philips 0 screws securing the keyboard.
      Ask FixBot
    2. Dell Inspiron Mini 10 Palm Rest Bracket Replacement: step 4, image 1 of 1
      • Turn over the device and open the display.
      • Gently pry open the keyboard with the plastic opening tool, working under the edges to release the clips.
      Ask FixBot
    3. Dell Inspiron Mini 10 Palm Rest Bracket Replacement: step 5, image 1 of 2 Dell Inspiron Mini 10 Palm Rest Bracket Replacement: step 5, image 2 of 2
      • Lift the keyboard off of the support bracket carefully since it is still connected by a ribbon cable.
      Ask FixBot
    4. Dell Inspiron Mini 10 Palm Rest Bracket Replacement: step 6, image 1 of 2 Dell Inspiron Mini 10 Palm Rest Bracket Replacement: step 6, image 2 of 2
      • Push the clips out on either side of the ribbon cable to release it.
      • Gently disconnect the ribbon cable by pulling on the clear tab.
      • Remove the keyboard.
      Ask FixBot
    1. Dell Inspiron Mini 10 Palm Rest Bracket Replacement, Palm Rest Bracket: step 7, image 1 of 1
      • Close the device and turn over.
      • Remove the five 8mm Phillips 0 screws.
      Ask FixBot
    2. Dell Inspiron Mini 10 Palm Rest Bracket Replacement: step 8, image 1 of 2 Dell Inspiron Mini 10 Palm Rest Bracket Replacement: step 8, image 2 of 2
      • Turn the device over and open the display.
      • Remove the single 8mm Phillips 0 screw attaching the hard-drive cage to the body of the device.
      Ask FixBot
    3. Dell Inspiron Mini 10 Palm Rest Bracket Replacement: step 9, image 1 of 2 Dell Inspiron Mini 10 Palm Rest Bracket Replacement: step 9, image 2 of 2
      • Pull on the black tab and slide the hard-drive cage toward the USB port on the left side of the device until its comes free and carefully lift out of device.
      Ask FixBot
    4. Dell Inspiron Mini 10 Palm Rest Bracket Replacement: step 10, image 1 of 2 Dell Inspiron Mini 10 Palm Rest Bracket Replacement: step 10, image 2 of 2
      • Remove the four 6mm Philips 0 screws securing the bracket.
      Ask FixBot
    5. Dell Inspiron Mini 10 Palm Rest Bracket Replacement: step 11, image 1 of 3 Dell Inspiron Mini 10 Palm Rest Bracket Replacement: step 11, image 2 of 3 Dell Inspiron Mini 10 Palm Rest Bracket Replacement: step 11, image 3 of 3
      • Disconnect the following:
      • Power button cable
      • Speaker cable
      • Power status light cable
      • Bluetooth cable (if installed)
      Ask FixBot
    6. Dell Inspiron Mini 10 Palm Rest Bracket Replacement: step 12, image 1 of 1
      • Gently pry off the bracket using the prying tool.
      Ask FixBot
Danielle Jarecki
358 Reputation
5 Guides authored
UW Tacoma, Team 1-4, Rose Fall 2016 Member of UW Tacoma, Team 1-4, Rose Fall 2016
UWT-ROSE-F16S1G4
4 Members
120 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 26
All Time: 533
