Up to 20% off select tools
Dell Inspiron M511R Module Cover Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
9
Past 30 Days:
50
All Time:
326
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Needs More Images
A few more images would make this guide's procedures crystal clear.
Community-Contributed Guide
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
    1. Dell Inspiron M511R Module Cover Replacement, REMOVE BATTERY: step 1, image 1 of 1
      • Insert wisdom here.
      Ask FixBot
    2. Dell Inspiron M511R Module Cover Replacement, Removing the Module Cover: step 2, image 1 of 1
      • Loosen the captive screw that secures the module cover to the base cover
      • Using your fingertips, release the tabs on the module cover from the slots on the computer base
      • Lift the module cover off the computer base
      Ask FixBot
    3. Dell Inspiron M511R Module Cover Replacement, removing memory module: step 3, image 1 of 1
      • Use your fingertips to carefully spread apart the securing clips on each end of the memory-module connector until the memory module pops up
      • Remove the memory module from the memory-module connector.
      Ask FixBot
    4. Dell Inspiron M511R Module Cover Replacement, Replacing the Memory Module: step 4, image 1 of 1
      • align the notch in the memory module with the tab in the memory-module connector.
      • Slide the memory module firmly into the slot at a 45-degree angle, and press the memory module down until it clicks into place. If you do not hear the click, remove the memory module and reinstall it.
      • Replace the module cover
      • Replace the battery
      Ask FixBot
Author
with
Jordon Dozier
1,663 Reputation
12 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
45 Members
12,349 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 9
Past 30 Days: 50
All Time: 326
