Dell Inspiron M5110 Palmrest Replacement
    1. Dell Inspiron M5110 Palmrest Replacement, Battery: step 1, image 1 of 1
      • Shut down the computer and turn it upside down.
      Ask FixBot
    2. Dell Inspiron M5110 Palmrest Replacement: step 2, image 1 of 1
      • Slide both of the battery release latches on the bottom of the device in towards the center of the computer.
      Ask FixBot
    3. Dell Inspiron M5110 Palmrest Replacement: step 3, image 1 of 1
      • Slide and lift the battery up and out from the device.
      Ask FixBot
    1. Dell Inspiron M5110 Palmrest Replacement, Keyboard: step 4, image 1 of 1
      • Open the computer and push the screen back as far as possible.
      Ask FixBot
    2. Dell Inspiron M5110 Palmrest Replacement: step 5, image 1 of 1
      • Slide a plastic opening tool into the slots on the top of the keyboard.
      Ask FixBot
    3. Dell Inspiron M5110 Palmrest Replacement: step 6, image 1 of 1
      • Pry the keyboard away from the device using the plastic opening tool.
      Ask FixBot
    4. Dell Inspiron M5110 Palmrest Replacement: step 7, image 1 of 1
      • Lift and slide the keyboard towards the screen to remove the tabs on the keyboard from the slots on the palmrest.
      Ask FixBot
    5. Dell Inspiron M5110 Palmrest Replacement: step 8, image 1 of 1
      • Flip the keyboard over and place it on the front of the device making sure not to pull out the keyboard cable.
      Ask FixBot
    6. Dell Inspiron M5110 Palmrest Replacement: step 9, image 1 of 1
      • Lift up the connector latch and remove the keyboard cable. The keyboard is now free from the device.
      Ask FixBot
    1. Dell Inspiron M5110 Palmrest Replacement, Palmrest: step 10, image 1 of 1
      • Turn the computer over and remove the six screws that secure the palmrest assembly
      Ask FixBot
    2. Dell Inspiron M5110 Palmrest Replacement: step 11, image 1 of 1
      • Turn the computer over and open the display as far as possible and remove the four 5 mm Phillips # 0 screw holding the palmrest in place.
      Ask FixBot
    3. Dell Inspiron M5110 Palmrest Replacement: step 12, image 1 of 2 Dell Inspiron M5110 Palmrest Replacement: step 12, image 2 of 2
      • Disconnect the power button board cable, touch pad cable and the hot key board cable from the connectors.
      Ask FixBot
    4. Dell Inspiron M5110 Palmrest Replacement: step 13, image 1 of 2 Dell Inspiron M5110 Palmrest Replacement: step 13, image 2 of 2
      • Use a plastic opening tool to carefully pry out the palmrest assembly and lift it off the computer base.
      Ask FixBot
Larain
411 Reputation
3 Guides authored
UMass Dartmouth, Team 4-3, Catania Fall 2016 Member of UMass Dartmouth, Team 4-3, Catania Fall 2016
UMASSD-CATANIA-F16S4G3
3 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 11
All Time: 396
