Up to 20% off select tools
Dell Inspiron M5030 RAM Replacement
Views: 2.9K
View statistics:
Past 24 Hours:
3
Past 7 Days:
22
Past 30 Days:
101
All Time:
2,948
Comments: 3
2 comments on steps, 1 guide comment.
Go to guide comments
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 - 10 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
This guide will teach you how to replace the RAM in the Dell Inspiron M5030 laptop. Replacing the RAM is one way to speed up a slower and/or older computer, and is a fairly simple process.
Once the RAM has been replaced, simply follow the steps in reverse order to reassemble the laptop.
Always exercise caution when handling electronic components.
    1. Dell Inspiron M5030 RAM Replacement, Keyboard: step 1, image 1 of 2 Dell Inspiron M5030 RAM Replacement, Keyboard: step 1, image 2 of 2
      • Remove all fourteen Phillips #0 7/16" screws from the bottom of the laptop.
      • Remove the two Phillips #0 5/16" screws from the bottom of the laptop.
      Ask FixBot
    2. Dell Inspiron M5030 RAM Replacement: step 2, image 1 of 2 Dell Inspiron M5030 RAM Replacement: step 2, image 2 of 2
      • Turn the laptop over and open the lid.
      • Locate the three tabs above the first row of keys on the top of the keyboard, found above the F1, F6, and PrntScr keys.
      • With one of your hands, push the leftmost tab down with the plastic opening tool (above the F1 key). With your other hand, lift the left side of the keyboard.
      • Push the middle tab down with the plastic opening tool and continue lifting from the left side of the keyboard to the right side (above the F6 key).
      • Push the rightmost tab down with the plastic opening tool and continue lifting from the left side of the keyboard to the right side (above the PrntScr key). The keyboard should be loosened from the laptop after these steps.
      Ask FixBot
    3. Dell Inspiron M5030 RAM Replacement: step 3, image 1 of 2 Dell Inspiron M5030 RAM Replacement: step 3, image 2 of 2
      • After the top edge of the keyboard is loose, pull up on the keyboard gently.
      • Do not pull the keyboard up forcefully as the keyboard is still attached to the laptop by a ribbon.
      Ask FixBot
    4. Dell Inspiron M5030 RAM Replacement: step 4, image 1 of 3 Dell Inspiron M5030 RAM Replacement: step 4, image 2 of 3 Dell Inspiron M5030 RAM Replacement: step 4, image 3 of 3
      • Pull up the bottom side of the keyboard and locate the ribbon connecting the keyboard to the motherboard.
      • Locate the blue end of the ribbon which is connected to the motherboard.
      • Lift up the black flap on the connector and gently pull the ribbon away from the connector which is parallel to the motherboard.
      • Lift the keyboard up and off of the motherboard. Detach the blue end of the ribbon from the connector.
      Ask FixBot
    1. Dell Inspiron M5030 RAM Replacement, RAM: step 5, image 1 of 3 Dell Inspiron M5030 RAM Replacement, RAM: step 5, image 2 of 3 Dell Inspiron M5030 RAM Replacement, RAM: step 5, image 3 of 3
      • Locate the two blue chips in the middle of the computer. These are the computer's RAM (Random Access Memory) chips.
      • Push outward on the metal tabs on the short ends of the upper RAM chip to loosen it. The left end of the chip should lift up, putting the chip at an angle.
      • Grab the lifted left edge of the RAM with your fingers, and gently slide it out.
      Ask FixBot
    2. Dell Inspiron M5030 RAM Replacement: step 6, image 1 of 3 Dell Inspiron M5030 RAM Replacement: step 6, image 2 of 3 Dell Inspiron M5030 RAM Replacement: step 6, image 3 of 3
      • Push outward on the metal tabs on the short ends of the lower RAM chip to loosen it. The left end of the chip should lift up, putting the chip at an angle.
      Ask FixBot
4 other people completed this guide.
Author
with
Ryan Moelter
382 Reputation
2 Guides authored
Cal Poly, Team 3-44, Maness Spring 2014 Member of Cal Poly, Team 3-44, Maness Spring 2014
CPSU-MANESS-S14S3G44
4 Members
72 Guides authored
1 Guide Comment
This is BY FAR the nicest and the most resourceful set of instructions for anything about any thing on the internet so far. And thrust me, when i say so far, it is a loooong time.
So, coincidentally i just gave my youngest (6 y.o.) this DELL Inspirion M5030 to play on it. Bu i really hate to disassemble it again just to look at the RAM module.
Can you help me and tell me which type it is there?
Is it possible that it is "just RAM" as the pre DDR2 type?
Ozren Kartalović - Reply Share
Past 24 Hours: 3
Past 7 Days: 22
Past 30 Days: 101
All Time: 2,948
