Dell Inspiron M5030 Keyboard Replacement
    1. Dell Inspiron M5030 Keyboard Replacement, Keyboard: step 1, image 1 of 2 Dell Inspiron M5030 Keyboard Replacement, Keyboard: step 1, image 2 of 2
      • Remove all fourteen Phillips #0 7/16" screws from the bottom of the laptop.
      • Remove the two Phillips #0 5/16" screws from the bottom of the laptop.
      Ask FixBot
    2. Dell Inspiron M5030 Keyboard Replacement: step 2, image 1 of 2 Dell Inspiron M5030 Keyboard Replacement: step 2, image 2 of 2
      • Turn the laptop over and open the lid.
      • Locate the three tabs above the first row of keys on the top of the keyboard, found above the F1, F6, and PrntScr keys.
      • With one of your hands, push the leftmost tab down with the plastic opening tool (above the F1 key). With your other hand, lift the left side of the keyboard.
      • Push the middle tab down with the plastic opening tool and continue lifting from the left side of the keyboard to the right side (above the F6 key).
      • Push the rightmost tab down with the plastic opening tool and continue lifting from the left side of the keyboard to the right side (above the PrntScr key). The keyboard should be loosened from the laptop after these steps.
      Ask FixBot
    3. Dell Inspiron M5030 Keyboard Replacement: step 3, image 1 of 2 Dell Inspiron M5030 Keyboard Replacement: step 3, image 2 of 2
      • After the top edge of the keyboard is loose, pull up on the keyboard gently.
      • Do not pull the keyboard up forcefully as the keyboard is still attached to the laptop by a ribbon.
      Ask FixBot
    4. Dell Inspiron M5030 Keyboard Replacement: step 4, image 1 of 3 Dell Inspiron M5030 Keyboard Replacement: step 4, image 2 of 3 Dell Inspiron M5030 Keyboard Replacement: step 4, image 3 of 3
      • Pull up the bottom side of the keyboard and locate the ribbon connecting the keyboard to the motherboard.
      • Locate the blue end of the ribbon which is connected to the motherboard.
      • Lift up the black flap on the connector and gently pull the ribbon away from the connector which is parallel to the motherboard.
      • Lift the keyboard up and off of the motherboard. Detach the blue end of the ribbon from the connector.
      Ask FixBot
4 other people completed this guide.
Ryan Moelter
382 Reputation
2 Guides authored
Cal Poly, Team 3-44, Maness Spring 2014 Member of Cal Poly, Team 3-44, Maness Spring 2014
CPSU-MANESS-S14S3G44
4 Members
72 Guides authored
2 Guide Comments
Do you know any ways to replace 4 keys Spacebar,B,N and the Slash/Question Mark are broken plz help
Snapchat Hotdog - Reply Share
The keyboard is best handled as a whole part replacement. You can find M5030 replacement keyboards for about $10 on Amazon/eBay.
Robert Johnson - Reply Share
Past 24 Hours: 3
Past 7 Days: 24
Past 30 Days: 104
All Time: 1,892
